C5 jack
Old Jan 12, 2006 | 12:14 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
Originally Posted by indy300
I don't like the looks of that at all! It doesn't even look physically possible to raise the car! As a structural engineer, I'll need more info on how that works.
My best suggestion is to get a AAA membership
Hmmmmmm well, I'm only a janitor at WalMart but it looks to me that this jack will work unless you are trying to lift the car on a sheet of ice. I see a lever, fulcrum, a way of moving the lever, a base that is somewhat stable if on a decent level surface....
Ok, OK... you got me... I'm really a janitor at BMW in South Carolina... but only part-time...
PS, no offense to any janitors, OK?
Old Jan 12, 2006 | 01:33 AM
SLPRC5's Avatar
SLPRC5
Wal*Mart
Electric jack workd great has a solid foot stand..no rocking or slipping. Less than $60.00 Plugs in cig/axillary outlet.
Old Jan 12, 2006 | 01:42 AM
SLPRC5's Avatar
SLPRC5
Originally Posted by mhdi22
Wish I had a pic to show it (car put away for winter), however; look in Auto Zone or a Walmart and try one of the "12 volt" jacks they have. Head of it fits easily within the "jacking space" and it works off the battery. Comes in a case, and it all fits next to the CD storage.
I wrote a POST on this awhile back and it got a lot of interest bringing positive and neg. comments..out come is that this jack works perfectly with safety in mind. The base of this jack is SOLID. It lifts the car fast and smooth, you can stand off to the side while lifting the car and keep an eye on traffic if need be. As you stated it fits under the car without any problems.
Here is a picture of it.
Old Jan 12, 2006 | 11:24 AM
Cole's Avatar
Cole
Originally Posted by BuckyBoy
Just to pass on something...
I've heard if you ever do jack up one side of your Vette, open the doors, or they'll pop off.
Food for thought
Not true.
Old Jan 12, 2006 | 11:35 AM
RiceEater Z06's Avatar
RiceEater Z06
Originally Posted by DickieC.99
Does anyone know how high this jack is when collapsed on the ground? If i'm not mistaken, I need something just under 3.75 inches....
I need to know as well, will the MB jack fit under lowered vettes also without having to drive up on blocks?
Old Jan 12, 2006 | 12:10 PM
kalister1's Avatar
kalister1
Just thinking out loud, but if you open the door to keep it from cracking......What is going to take the stress? It seems that if the door is closed the car will be more rigid than with them open?
Old Jan 19, 2006 | 08:01 AM
C5 Frederik's Avatar
C5 Frederik
Hi, this is C5 Frederik, seller of the "Little Lifter"
lowest hight is 80mm or 3.15 "
It is still $50.00 including shipping.
It´s from the actual E-class (not C-class, as this takes a lower load)
It is perfect to change one wheel, i.e. on emergency or on the track.
It is not to be used to lift complete side of car i.e. to do work on swaybars.
It fits perfect in one of the two small rear compartments.
There are more than 360 happy customers, and there is one unhappy one (forgot his name, he had problems to handle it)
If there are any questions, please ask.
Frederik
Old Jan 19, 2006 | 08:19 AM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
I have a related question.... does anyone know where/if the lug nut wrench is stored in a C5? Can't find it anywhere.
Old Jan 19, 2006 | 10:39 AM
Speed Trap's Avatar
Speed Trap
My lug wrench was stored at Kragen Auto Parts. I've started keeping it in the car for convenience. I got one of the extendable lug wrench's for $12.95, Very compact.
GM didn't include one in the models with runflats, don't know about the Z06's.
Old Jan 19, 2006 | 11:49 AM
1FUNVTT's Avatar
1FUNVTT
Old Jan 19, 2006 | 12:55 PM
W Muller's Avatar
W Muller
Default jack
Just about any little scissor jack will work. I bought one at a yard sale. It goes lower then 2” and cost $1.00. You might want to use a puck or a little steal plate between the jack and frame to keep from denting the frame.
Old Jan 19, 2006 | 03:47 PM
Z06HPISFUN's Avatar
Z06HPISFUN
St. Jude Donor '07
Thanks.
Old Jan 19, 2006 | 05:15 PM
  #33
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
If you're carrying a plug kit and a compressor, why do you even need a jack?
Old Jan 23, 2006 | 03:06 AM
  #34
2MuchRiceMakesMeSick's Avatar
Originally Posted by RstyNutz
Wal*Mart
Thats interesting. I guess since im fresh out of spares...it wont do me much good
Old Jan 23, 2006 | 04:48 AM
  #35
CorvetteSteve's Avatar
CorvetteSteve
Old Jan 23, 2006 | 10:25 AM
  #36
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
After seeing some of the damage caused by faulty plugs in the parts business many moons ago, I would recommend just using the run flats to get someplace where the tire can be properly patched from the inside or replaced. If you don't have run flats, a plug is good for a few miles at lower speeds. Just don't rely on them as a permanent fix because have a tendency to wear out and remove themselves. If you ask most service/ parts shops, they will sell a plug kit but will not install a plug.
The jack would be nice for those days in the garage when I want to get in there and clean all that god-forsaken brake dust off the inside of the rims
Old Feb 20, 2006 | 04:23 PM
  #37
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi C5 Frederik -
If I can get me a GTO spare, I'll be ordering one of these from you soon!
best regards -
mqqn
Old Mar 14, 2006 | 02:24 AM
  #38
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
