window pinches ragtop
Old Dec 23, 2005 | 02:24 PM
gtbbaby's Avatar
gtbbaby
Default window pinches ragtop
98 convertible - when weather gets cold the top rear corners of both windows "pinches" the top, stays on outside of top - won't seal properly - it's wearing the corners of the top - warm weather it's fine ? anyone else experience this and/or solutions - thanx
Old Dec 23, 2005 | 02:40 PM
6spdC6's Avatar
6spdC6
Active Streak: 90 Days
From: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I had this in my 98 vert. There are tip in tip out adjustments inside the doors. It adjusts the glass a bit, that will cure it. This happened back in 98 so I forgot just how I did it. This was common in the early verts.
Old Dec 23, 2005 | 02:43 PM
DeeGee's Avatar
DeeGee
PM me with you e mail address. I have some notes I made from a previous post on this problem.
Old Dec 23, 2005 | 03:41 PM
GrayC5's Avatar
GrayC5
Convertible care, adjustments, and tips
Old Dec 23, 2005 | 03:45 PM
99 vett babycar's Avatar
99 vett babycar
Originally Posted by GrayC5
Old Dec 23, 2005 | 08:36 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Mine had that problem on the passenger side. An adjustment (I didn't do it) took care of it.
Old Dec 24, 2005 | 12:25 AM
DeeGee's Avatar
DeeGee
Thats the thread
Old Dec 24, 2005 | 06:07 AM
edensknight's Avatar
edensknight
Great link! Tip in adjustment is simple and really helps.
Old Jan 5, 2006 | 01:32 PM
slpippen's Avatar
slpippen
My 2000 has the same exact problem. It has started to tear the convertible top so I have been struggling to push the window in as I close the door. My daughter rode with me yesterday and noticed that the passenger side window is doing the same thing.
Thanks for the fix tip. I will get my hubby to take a look.
Old Jan 17, 2006 | 05:11 PM
Hammie's Avatar
Hammie
That's a great link, but I did not see where it showed how to tilt the window in to not hit the top. I'd like to try that before I try raising the top itself as the link suggests.
Can someone enlighten me where I need to look for the window adjustment?
Old Jan 18, 2006 | 09:15 AM
biged666's Avatar
biged666
My newly purchased '00 Vert does this as well. I am planning to install the Window valet to resolve this issue. CLosing the windows after closing the doors makes the windows seal properly.
Old Jan 18, 2006 | 11:53 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Hammie,
I haven't done it yet on our 2000, and would suggest reading all the info first, but that said, the tip in adjustment info is in our 2000 FSM.
See: Volume 3, Air/Wind Noise Door Window, page 8-800, corrective Action #2 (for the spec)
See: Volume 3, Window Tip-In Adjustment - Door, page 8-1134 (for the procedure)
Note our 2000 book notes requiring a #6 inverted Torx Socket, and that's really small, a 1/4 inch socket is still a bit big, on ours it looks more like a standard SAE or Metric 6-point socket will work (instead or Torx).
Old Jan 18, 2006 | 01:44 PM
Hammie's Avatar
Hammie
Thanks admiral. Helps a bit but I'm gonna need some FSM's before I tackle it, it looks like, unless someone can inform us over this thread.
Old Jan 18, 2006 | 07:09 PM
Autoworker's Avatar
Autoworker
I had the same problem with my "98. Buds Chevy is one of the bigger Vette dealers in Ohio. They pulled the door panels and moved the whole window forward. Said the tip in / out adjustment wouldn't have worked. The fix cost around $100 and works great.
Old Jan 18, 2006 | 10:28 PM
TorchRedRaider's Avatar
TorchRedRaider
Yep, but I had to adjust the top per this pic to get mine to stop tearing the top.
http://www.c5forum.com/ayc/topcare/pic1.jpg
The adjustment nut and jam nut is pictued under the yellow error, not what its pointing at. (hey i didnt shoot the pic)
To window pinches ragtop
