Road noise
Old Dec 23, 2005 | 07:14 PM
Gary French's Avatar
Gary French
Default Road noise
When I put an exhaust system on what is the best way to insulated the interior from noise. I have a convertible. Is that noise blocker that fits behind the seats any good or is there an insulater I can put under the carpet ----and is that a big job.
Old Dec 23, 2005 | 07:21 PM
binkysgarage's Avatar
binkysgarage
You can do both each one will help alittle bit, I have a FRC and it was worth while for both mods. The sound deadener install take a good day to do but worth it.
Old Dec 23, 2005 | 08:04 PM
Dr. Dan's Avatar
Dr. Dan
I've done both. The Partition that I have goes between the ragtop and the trunk, and helps keep the top clean from junk in trunk. Insulation under the carpet and in all 3 storage areas dramatically reduced the noise. Call Dan, a supporting vendor, at www.ExoticVette.com and he'll hook you up with precut pieces. Not that big a deal to do.
Old Dec 24, 2005 | 11:00 AM
southerncarparts's Avatar
southerncarparts
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
The Convertible partition works pretty good.
We have them as well in matching Black, Light Oak and Pewter Grey.
Jim
Old Dec 24, 2005 | 11:46 AM
TripleBlackxThree's Avatar
TripleBlackxThree
St. Jude Donor '07
Hope you will post your results. My vert was really loud with runflats and exhaust. Fixed the runflat situation this week... at least I hope I did.
Let us know what you decide...
Old Dec 24, 2005 | 11:52 AM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Jim
I just ordered one in black for my C5 Vert. $130 shipped ($50 less than Exotic Vettes). Hope it works.
Merry Christmas!
Old Dec 25, 2005 | 06:15 PM
scottydog's Avatar
scottydog
I took out most of my road noise with new non-runflat tires, and Frost King insulation mod.
Old Dec 25, 2005 | 06:16 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Change your runflats and do this .
Old Dec 25, 2005 | 11:21 PM
mixermike's Avatar
mixermike
insulation kit from Dan at exotic vette is very good
Old Dec 26, 2005 | 11:08 AM
Mike Mercury's Avatar
Mike Mercury
http://mikemercury.home.att.net/sound.htm
Old Dec 26, 2005 | 11:10 PM
edensknight's Avatar
edensknight
Jim
Old Dec 27, 2005 | 07:02 AM
c-5-steve's Avatar
c-5-steve
I put a trunk mat from Lloydes in my vert. It cut down the noise.
Old Dec 27, 2005 | 08:10 AM
rws.1's Avatar
rws.1
There are three things you can do to dramatically reduce road noise.
A trunk partition from forum member Crazy Cowboy at
www.exoticvettes
A trunk carpet form Lloyds mats
those two combined dramtically reduce exhaust drone in a Vert
The last step is the expensive one.... replace the runcraps!
Old Dec 27, 2005 | 10:08 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Originally Posted by Mike Mercury
To Road noise
