C5 Interior Lighting
Old Dec 24, 2005 | 12:24 PM
c4cruiser's Avatar
c4cruiser
Default C5 Interior Lighting
So after a couple months of ownership, I pretty much feel that the level of interior lighting in the coupe is teh suck. The lights in the bottom of the interior mirror are OK but the rear compartment lights and the underdash lights just don't do much to effctively light up the interior at night.
Anyone have any suggestions for improving the lighting so I can actually see inside the car at night? Can you just go with higher wattage bulbs? Are there LED replacement bulbs?
Old Dec 24, 2005 | 12:30 PM
scaperman's Avatar
scaperman
A lot of the guys are replacing with Led lights
Old Dec 24, 2005 | 12:34 PM
AlanN's Avatar
AlanN
If I had the know how I would replace every light with a red one. I like it on the dark side in the cockpit at night and the green is just too bright. When I turn it down to where I like it I can see the Guage pod but not the radio controls.
Old Dec 24, 2005 | 12:38 PM
c4cruiser's Avatar
c4cruiser
Used to be able to get lightbulb dye years ago. I had a 55 Chev with all red interior lights and dash lights. Just dipped the bulb in the dye and let it dry. Never had a problem with the dye burning off.
Old Dec 24, 2005 | 03:44 PM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
Eeee Yup! Got my LED's at www.superlumination.com
Old Dec 24, 2005 | 04:43 PM
dwspas's Avatar
dwspas
Changed mine over to red LED's and they work great. There are a few how-to-do's here on the forum. Do a search for LED's. You'll like the results and the project is not that hard with the exception of the HVAC and Radio but if you take your time they works out great.
Old Dec 25, 2005 | 12:03 PM
grunz95's Avatar
grunz95
Default Leds
I like what you did, would you mind if I copy this application on my 99 coupe? Could you tell me what part numbers I need to order.
Thanks, Gary
grunz95@sbcglobal.net
Old Dec 27, 2005 | 12:19 AM
edensknight's Avatar
edensknight
Daves set up is the shiznit!
To C5 Interior Lighting
