Brake pedal travel question. Normal?
Old Dec 27, 2005 | 01:52 PM
BrianWe's Avatar
BrianWe
Default Brake pedal travel question. Normal?
It seems like the distance the brake pedal travels before the brakes engage changes. Sometimes just a tap and the brakes are on and other times, you have to push it an inch or more before anything happens. Is this normal? My brakes function well and the fluid level is correct. I just wondered if this is cause for concern and indicative of a problem. Thanks for the insight.
Old Dec 27, 2005 | 02:44 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
I'd be a little concerned, if this were my car. My '98 is 7years old w/18k miles and I do not have this kind of variation in the brake peddle. Just my opinion. Good luck.
Old Dec 27, 2005 | 02:47 PM
AU N EGL's Avatar
AU N EGL
Ok you are experiencing a few things here: brake fade and brake pad taper.
what to do:
1. Need to FLUSH and replace not top off the brake fluid. Yor brake fluid is too old.
2. New brake pads are in order, those are just about shot. if the pads have an uneven ware, then look at #3 below
3. check the caliper brakets, they may be bent. If so time to replace the brakets too.
Not too bad. about 2 hours for DIY if you know what your doing, 3 hours if you dont.
Good project.
Oh look at your rotors while you have every thing apart.
Good Luck
Old Dec 27, 2005 | 08:02 PM
edensknight's Avatar
edensknight
what to do:
Good project.
Good Luck
Attend to your brakes ASAP.
Old Dec 27, 2005 | 10:24 PM
BrianWe's Avatar
BrianWe
Thanks. I'll fix them ASAP.
Old Dec 27, 2005 | 10:35 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I've flushed non ABS brakes with a suction gun type bleeder. Can you do ABS brakes the same way?
Old Dec 28, 2005 | 09:32 AM
AU N EGL's Avatar
AU N EGL
No Never use a 'suction' or vacuum bleeder on any brake lines. always PUSH the fluid though the lines.
Vacuum bleeding if done too fast can seperate the fluids. It is much quicker and safer to use the power bleeder. the 10-15 psi of pressure is more then enough to go though the ABS modules and the caliper.
Old Dec 28, 2005 | 10:00 AM
willpall's Avatar
willpall
This is interesting to me because I am getting ready to replace my brake lines and was going to vacuum bleed them. If I create a perfect vacuum at the bleed screw, isn't that the same as applying 14 psi to the other end? If not, where do the fluids separate and how much of an issue is this?
Old Dec 28, 2005 | 10:50 AM
AU N EGL's Avatar
AU N EGL
Cant really Create thtat "perfect vacuum" and this the problem. air gets sucked though the tygon tude bleed valve connection.
Part of the bleeding process is seeing bubbles, if any and or color change of the fluid thought they clear tygon tubing attached the bleed valve as it drains in to an old bottle or what ever you use.
I use an old 16 oz plastic coke bottle with a hole drilled in the cap and put the tygon tube though that.
If you dont have the power bleeder then it becomes a two person opperation. One to pump and hold down the brake peddle and one to bleed.
Good Luck
Old Dec 30, 2005 | 12:38 PM
willpall's Avatar
willpall
Maybe YOU can't create that "perfect vacuum" but I can. Everything I do is perfect. Never made a mistake in my life...
Good Luck
This all makes sense. Thanks for the tip.
Old Dec 31, 2005 | 07:23 PM
schtick's Avatar
schtick
Another thing, if you unhook your brake lines from the calipers you'll need to replace the copper washers that are on both sides of the line. I just had my calipers powdercoated and didnt replace them so when I tried to bleed the brakes, they leaked. I replaced those washers and all was well. I bought them at the local GM dealer. They werent expensive.
Old Jan 1, 2006 | 08:12 AM
Lancer033's Avatar
Lancer033
Or you can take one of the cold copper washers to any autoparts or hardware store and buy 8 copper washer of the same size, cost between $0.25 and $1 for all of them. The last set I got wern't as think as the origionals, but still did the job.
To Brake pedal travel question. Normal?
