Why would anyone do this?
Old Dec 28, 2005 | 10:19 PM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Default Why would anyone do this?
In the process of moving my XM antenna to under the rear bumper cover my project expanded in scope as I noticed some unusual things under the rear carpet of my car . This is my first C-5, but I'm fairly sure that GM didn't put it there.
Anybody have a clue why someone would glue plywood and 1x1's along the fenderwells? Also looks like something was glued further out into the floor also.
Old Dec 28, 2005 | 10:22 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Old stereo install
Old Dec 28, 2005 | 10:23 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Looks like someone may have had some sort of huge sound system in it?!
Old Dec 28, 2005 | 10:25 PM
C5naples's Avatar
C5naples
Originally Posted by EnglandGreen
Old stereo install
Old Dec 28, 2005 | 10:26 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
Old Dec 28, 2005 | 10:37 PM
Chicago's Avatar
Chicago
St. Jude Donor '15
Did they use Liquid Nails? If so, yikes!
Old Dec 28, 2005 | 10:41 PM
troy144's Avatar
troy144
Looks like audio install extras like others are saying get it out of there
Old Dec 28, 2005 | 10:42 PM
troy144's Avatar
troy144
I agree with everybody else. Just clean it up and get it out of there
Old Dec 28, 2005 | 10:44 PM
Lovin It!!! - C5
Not sure. Some of it looked like clear silicone, but was very hard, kinda like hot glue. (A major Bi^# to remove). Then there was some tan stuff that was hard as a rock.
Had to (CAREFULLY) use a hammer and chisel to scrape it all off.
Ended up covering everything with Dynomat by the time I was done.
A major stereo install was my thoughts too. But man, what a LOUSY install!!!
Old Dec 28, 2005 | 11:08 PM
b98's Avatar
b98
Old Dec 28, 2005 | 11:30 PM
0EG@EnglandGreen
Supporting Tuner
I agree. That is NOT how it is done.
I attached my amps via short screws to pieces of MDF under the carpet - but they were "floating" above the chassis and could be removed in a couple of minutes.
No holes in the structure and no glue
Here's a pic. The amp is bolted through the panel to MDF behind it.
Old Dec 28, 2005 | 11:37 PM
tmcclaff's Avatar
tmcclaff
St. Jude Donor '04 & '05
Glad you got it all off and that dynomat will help a lot
Old Dec 29, 2005 | 07:47 AM
Yea, had to be something like a stereo install. Sure didn't come from the factory that way.
Old Dec 29, 2005 | 07:59 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Here's one more vote for old audio install
Old Dec 29, 2005 | 08:03 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Was this used to mount one of those 1000 watt eardrum destroyers?
Bob
Old Dec 29, 2005 | 08:09 AM
Tom/99's Avatar
Tom/99
Old stereo install
Old Dec 29, 2005 | 08:20 AM
BiggieBoy's Avatar
BiggieBoy
Tried to make a pickup truck out of it???????
To Why would anyone do this?
Old Dec 29, 2005 | 08:41 AM
BobbyG's Avatar
BobbyG
Old Dec 29, 2005 | 08:57 AM
Dark-Knight's Avatar
Dark-Knight
Your Dynomat solution is a good one...
Old Dec 29, 2005 | 09:10 AM
0EG@EnglandGreen
Supporting Tuner
Bob
Like this?
