Lr Tire Pressure
Old Dec 31, 2005 | 12:25 PM
Mike Mercury's Avatar
Mike Mercury
Originally Posted by Paras
Actually, I just found that you have to drive the car around for like five minutes before the pressure reading adjusts...
same here.
I once read -but never confirmed- that there is a centrifugal-force switch inside the (newer model) sensors that activates it - only when the wheel is spinning; this to save battery life. Once parked, the BCM/PCM simply remembers the last reported pressures from the sensors. Until you drive the car again - the DIC may not see the updated pressures.
Old Dec 31, 2005 | 12:54 PM
vettman96's Avatar
vettman96
Originally Posted by charlene
Those sensors can drive you crazy i have a compressor in the garage and i always check the tires on the vette and the gage will read 30psi on all the tires but the dic will read differently one might read 30 another 29 so i don't think the sensors are perfect i usually go by my gage..........Charlene
I trust my tire gauge, the sensors are just whiz bang toys
Old Dec 31, 2005 | 03:32 PM
miamivette02's Avatar
miamivette02
Originally Posted by Wisdom
As a matter of fact - I took my car into a local Clear Lake chevy dealership in October for warranty work. Ever since the car came back I seemed to lose maybe 1.25 lbs per day from one of the rear tires. The dealership had no business working in the tire area, so it had to be something else. So every chance I had I was on the ground looking at the tire for the suspect nail. Yesterday I finally had my tires replaced with Nitto 555's from Discount Tire. There was no nail in my problem tire. Today my rear Nitto's pressure was lower than yesterday's - so I finally woke up and used a 12mm wrench to tighten the valve stem. My problem tire's valve stem (aka pressure sensor) was looser than it should have been. I suspect that tomorrow morning that tire will have the same pressure as the others. I don't know how the sensor would have gotten loose all of a sudden in conjunction with the dealership visit. But you may want to check the valve stem to make sure it's tightened. There's a rubber o-ring or some sort of seal on them and I don't know if there's a torque value. But you should be able to tell if your problem one is looser than a good one.
- Wisdom
Thx for the suggestion...I will check it. I actually had my tires replaced today, so I will monitor the problem to see if it persists. If the technician tightened the sensors correctly, then this may go away.
