Lr Tire Pressure
Old Dec 29, 2005 | 01:11 PM
sprk33's Avatar
sprk33
2018 Grand Sport
Default Lr Tire Pressure
I keep getting msg in DIC that LR tire pressure is low. I have put air in it checked it with two air guages says 35 and DIC rpts. After putting air in I reset the DIC. Still coming up 25 on DIC. Do the sensors in the tires go bad often ? How much do they run ?
Old Dec 29, 2005 | 01:20 PM
YellowPowerC5's Avatar
YellowPowerC5
Try repgramming the sensors. if still no good chances are it is dying.
I paid $80something from fred beans
Good luck
Old Dec 29, 2005 | 01:29 PM
jdec's Avatar
jdec
Good luck
I agree with yellowpower C5 but if you want to chance a used sensor check ebay. You can usually pick up a whole set for 80 dollars on there. Just my .02.
Old Dec 29, 2005 | 01:36 PM
sprk33's Avatar
sprk33
2018 Grand Sport
How do you reprogram it.....?????
Old Dec 29, 2005 | 10:13 PM
sprk33's Avatar
sprk33
2018 Grand Sport
anyone ever reprogrammed ???
Old Dec 29, 2005 | 10:18 PM
NealB's Avatar
NealB
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Dec 30, 2005 | 08:05 AM
If a reprogram doesn't work, then it may be a bad sensor. Sensors are about $85 each and they normally have a life expectancy of between 5 and 8 years.
Old Dec 30, 2005 | 08:07 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The sensors are battery powered and are expected to last 5 to 7 years on average. They were designed to be non-serviceable as they are a sealed unit. There have been some reports of owners having luck replacing the battery in them. A search should reveal at least a couple of threads on this procedure. I have yet to read about the long term reliability after a battery change. There are two different sensors, one type for '97-'00 and one type for '01-'04. They are not interchangeable as the receiver is different so be careful if you go the ebay route. You can try retraining as posted in the procedure above and it that doesn't do it, you might need to replace it. I'd recommend one of the forum dealers like Fichtner's or Fred Beans as they sell parts to forum members at a discount.
Paul
Old Dec 30, 2005 | 10:34 AM
vette0067's Avatar
vette0067
I had the exact same problem. I took it into the dealer (I didn't ask the forum first..... ) All they did was reset the sensors and it's working great now.
Old Dec 30, 2005 | 12:09 PM
miamivette02's Avatar
miamivette02
I've never had this problem, but incidentally, my LR tire has been consistenly losing air much faster than the rest of the tires, and a buddy of mine with a C5 has the same problem. Has anyone else seen this?
Old Dec 30, 2005 | 04:13 PM
Wisdom's Avatar
Wisdom
As a matter of fact - I took my car into a local Clear Lake chevy dealership in October for warranty work. Ever since the car came back I seemed to lose maybe 1.25 lbs per day from one of the rear tires. The dealership had no business working in the tire area, so it had to be something else. So every chance I had I was on the ground looking at the tire for the suspect nail. Yesterday I finally had my tires replaced with Nitto 555's from Discount Tire. There was no nail in my problem tire. Today my rear Nitto's pressure was lower than yesterday's - so I finally woke up and used a 12mm wrench to tighten the valve stem. My problem tire's valve stem (aka pressure sensor) was looser than it should have been. I suspect that tomorrow morning that tire will have the same pressure as the others. I don't know how the sensor would have gotten loose all of a sudden in conjunction with the dealership visit. But you may want to check the valve stem to make sure it's tightened. There's a rubber o-ring or some sort of seal on them and I don't know if there's a torque value. But you should be able to tell if your problem one is looser than a good one.
- Wisdom
Old Dec 30, 2005 | 04:18 PM
HummelS's Avatar
HummelS
Good advice - especially in cooler weather, the o-rings might harden enough to lose their seal. There is a torque value, but I don't have the manual with me right now. It's not much, so I would just make sure the nut is tight.
Old Dec 30, 2005 | 04:30 PM
sprk33's Avatar
sprk33
2018 Grand Sport
I made sure it was tight it seems ok today. I had left it sit for a bit but all the others were fine. just the LR....Just goes to show you ...you have to give your baby attention or it will give you signs that you have not LOL
Old Dec 30, 2005 | 04:31 PM
gredmer's Avatar
gredmer
All four of my sensors are approx. 3 lbs off. When cold at 30 psi the sensors read 27. Since I can add pretty well I always know the correct temperature.
Old Dec 30, 2005 | 04:46 PM
Paras's Avatar
Paras
Actually, I just found that you have to drive the car around for like five minutes before the pressure reading adjusts...
Old Dec 30, 2005 | 05:00 PM
LoneStarFRC's Avatar
LoneStarFRC
For the '97-'00s it's approx. 106 to 109 inch pounds. I was checking mine a few weeks ago and found a couple that needed a little snugging up after my wheel change.
Just remember: the nuts are aluminum so try to get the torque as close as you can without overtightening. HTH
Old Dec 30, 2005 | 09:43 PM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Those sensors can drive you crazy i have a compressor in the garage and i always check the tires on the vette and the gage will read 30psi on all the tires but the dic will read differently one might read 30 another 29 so i don't think the sensors are perfect i usually go by my gage..........Charlene
To Lr Tire Pressure
Old Dec 30, 2005 | 10:46 PM
ErnieD's Avatar
ErnieD
St. Jude Donor '16-'17,'19
If you have reprogrammed your tire pressure sensors, you will have already eliminated this possible problem. If you haven't reprogrammed, the following situation is distinctly possible -- in fact, it happened to me. If the sensors have been removed from the wheels during a tire or wheel change, they could have been replaced on different wheels. If so, and they were not reprogrammed thereafter, everything would appear to be working correctly. But when the DIC reports a low tire, the actual low tire is a different one than specified on the DIC. Have you checked the pressure in ALL the tires to see if any one of them is low? Of course the real fix here is just to reprogram the sensors.
Ernie
Old Dec 30, 2005 | 11:33 PM
D C's Avatar
D C
USMC (retired)
I am having the same problem only with my LF. I will check to see if it tighten though at the stem and then see about reprogramming them.
I am glad this thread popped up because I was going to ask sooner or later. This CF is awesome.
Old Dec 31, 2005 | 11:21 AM
HJS815's Avatar
HJS815
Default tire pre sure value stem problem
- Wisdom
Sometimes there is a problem that we can resolve easy and we do the extreme first. I, too, found a loose nut and it resolved a pressure loss problem. On your next tire change, install new o-rings on the sensors at a cost of $6-10. Cheap insurance!
