Paging Patches
Old Dec 30, 2005 | 11:05 AM
EZEDDIE's Avatar
EZEDDIE
Default Paging Patches
I saw that you were on-line. First, welcome back. I missed your wisdom and exacting answers to all questions known to mankind. I wanted to ask if you regularly maintain your cut-outs? If so, what do you do? Also, do you remove your 'down turn' pipes to get to the units? If not, how do you access them since the turn downs are probably a few inches long and only 2.5 inches in diameter?
Thanks!
Ed
Old Dec 30, 2005 | 02:14 PM
EZEDDIE's Avatar
EZEDDIE
ttt
Patches, dying to hear you chime in with your experiences with cut outs. I really want this mod but am getting scared away by the notion of monthly maintenance and parts failing due to heat.
Thanks.
Old Dec 30, 2005 | 03:17 PM
Patches's Avatar
Patches
I only do maintenance once a year so far. They are very easy to get to and remove. I unbolt both the turndowns and cutouts simultaneaously since they use the same bolts for mounting, clean them up a bit, lube them and give them a new coat of RTV high temp sealant.
Old Dec 30, 2005 | 03:33 PM
EZEDDIE's Avatar
EZEDDIE
Thanks for the reply!
To Paging Patches
