Frame Savers
Old Dec 30, 2005 | 02:32 PM
DeeGee's Avatar
DeeGee
Default Frame Savers
I fitted the rocker rail protectors from A&A Corvette. They went on fairly easily and its a good snug fit.
I've just started on the frame savers. Drilling the skid bar to take the bolt is proving quite a job. That metal is hard I think my little drill is struggling. Has anyone else had similar problems or do I just need to grit my teeth and press on?
Old Dec 30, 2005 | 02:40 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Are you using a good steel bit?
Old Dec 30, 2005 | 02:42 PM
1FUNVTT's Avatar
1FUNVTT
I used a 18 volt Dewalt drill and a titanium drill bit. But I started to drill the hole with a smaller bit first before drilling with the correct size diameter bit stated on their instruction. Had no problem.
Old Dec 30, 2005 | 02:50 PM
DeeGee's Avatar
DeeGee
Originally Posted by 1FUNVTT
I used a 18 volt Dewalt drill and a titanium drill bit. But I started to drill the hole with a smaller bit first before drilling with the correct size diameter bit stated on their instruction. Had not problem.
I'll give that a try. I have the attention span of a gnat and its getting a bit tedious
Old Dec 30, 2005 | 03:08 PM
DeeGee's Avatar
DeeGee
The pilot hole trick worked a treat. Thanks very much
I just love this Forum
Old Dec 30, 2005 | 03:19 PM
sdef's Avatar
sdef
St. Jude Donor '10
1. car is off the ground
2. with a hammer and punch put a depression for one of the holes
3. using a good electric drill (forward speed) and a small bit drill a pilot hole
4. drill with the proper size bit
5. attach the plate but leave the bolt loose
6. repeat #2-4
my guess is you have a bad bit or a drill not appropriate for the job.
Old Dec 30, 2005 | 04:00 PM
edensknight's Avatar
edensknight
Old Dec 30, 2005 | 04:55 PM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
You should try using the end with the flutes... If you use the solid end, it may take a while...
longer,
Hmmm I bet it's getting hot, huh?
Old Dec 30, 2005 | 05:42 PM
DeeGee's Avatar
DeeGee
longer,
Its amazing what a more powerful drill and a pilot hole will do. I suspect my half watt black and decker just wasn't up to it
10 minutes and they're fitted. Just hope I don't need to use them now
Old Dec 30, 2005 | 05:49 PM
TexCzechVette's Avatar
TexCzechVette
Thanks to DeeCee for asking the question and for all the inputs - my set of frame savers and frame rails are on the work table waiting to get the car on the lift. Know I know exactly what to do - including using the sharp end of the drill bit. I only have a hand powered drill, but that should work as long as I have a sharp bit, right?
Gotta love the Forum - all the news and info all the time!
Old Dec 30, 2005 | 05:53 PM
sdef's Avatar
sdef
St. Jude Donor '10
fantastic!
save the cordless for drilling into soft wood around the house! always buy the best power tools you can afford. for power tools (gas, electric, air) you always want to have a power reserve.
Old Dec 30, 2005 | 06:15 PM
DeeGee's Avatar
DeeGee
Originally Posted by sdef
fantastic!
I have the most powerful electric drill known to man. It runs on 240 volts but............................It's in storage in England.
To Frame Savers
