talon is correct. I purchased from Mr. Dickman this past July. I ordered mine on a Sun. and received them on Tues. He includes excellent instructions also. Bruce
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Just did mine this week - got the kit from Rodney Dickman too.
My hands and forearms are still scabbing over..... It's actually easy once you have the headlight assembly out - but getting the two bolts on the side into the frame and the three on the back mounted to the fender is like sticking your hands into a meat grinder! (I guess my hands and forearms are too fat for this job.... )
Good luck - and replace both of them even if it's only one acting up!
If you put the car up on ramps you can remove a lower cover that gives you plenty of access to get to all of the bolts. It makes it alot easier than trying to get your arm in under the headlight.
