Headlight Lift Problem
Old Dec 31, 2005 | 04:12 AM
FNbad01C5's Avatar
FNbad01C5
2nd Gear
Default Headlight Lift Problem
Every so often my headlight motors take a little time to open. Other times they open as soon as I hit the switch. Not a real problem yet however I would like to fix B4 it is one. Any ideas why the delay?
Old Dec 31, 2005 | 06:00 AM
Shane_S's Avatar
Shane_S
Do both lights do it at the same times? If so then you might have an electrical problem somewhere. a small intermittant short maybe.
Shane
Old Dec 31, 2005 | 09:32 AM
DeeGee's Avatar
DeeGee
I could be way off the mark and other smarter guys may chip in.
If you have twilight sentinel enabled, as the sensor detects low light it brings up the lights. Theres an automatic delay built in so you don't get "flapping headlights". If the sensor has demanded a flip up, it will take a while before the command is activated. Watch the delay when you drive into a tunnel. It takes maybe 10 secs to flip up as you enter and then the same to flip down as you exit.
On manual with no twilight sentinel, the lights should flip up instantaneously.
Try enabling TS and then disabling it. See if you get the same delay in both modes.
Just a thought
Old Dec 31, 2005 | 11:34 AM
VRROOOM2's Avatar
VRROOOM2
St. Jude Donor '06
WOW!! Your very first POST!!
I have the same problem... However, if I tilt the steering wheel a couple times up and down, the lights will then work. I always figured it was in the steering column and finally asked about it a few weeks ago and was told to start in the connector at the base of the steering column.
Baby is stored waiting for warmer days so I haven't taken a look yet.
my 2 cents...
Happy New Year!!
Old Jan 7, 2006 | 06:07 PM
FNbad01C5's Avatar
FNbad01C5
2nd Gear
A little late getting back online...I also believe that it is an electrical issue as both lights stay down and come up together. When this happens I turn the switch on and off and they usually come up. Just annoying.
Old Jan 7, 2006 | 06:10 PM
troy144's Avatar
troy144
Old Jan 7, 2006 | 06:35 PM
Fast Lane's Avatar
Fast Lane
CI 3-4-5-6-7-8-9-10 Veteran
Mine wouldn't go up sometimes while driving. I discovered a slightly loose batt ground at the frame. Now they go up quickly anytime.
To Headlight Lift Problem
