Low Beam problem - FIXED
Old Dec 31, 2005 | 06:19 AM
Cole's Avatar
Cole
Default Low Beam problem - FIXED
I have been suffering for while with an intermittent low beam problem. The low beams would just fail to come on - sometimes they would flicker and at others - simply wouldn't go. My poor baby was becoming a daytime only driver. Very sad.
I came here to the experts and consensus was a grounding problem along with guidelines and recommendations for checking the various ground locations, I admit that I was suspicious of ground circuitry especially since I had installed headers and the law of unintended consequences could have been in force. Murphy has become a close personal friend throughout my life - especially when working on my cars
So I girded my loins for battle, put a new battery in in my Radio Shack Multimeter, downloaded schematics and wiring diagrams and approached baby with kind, loving and soothing words along with a gentle pat on the fender. I started at the headlights and noticed contact realys that could be disconnected and easily checked with a meter. I started on the drivers side, found an open and switched the two contacts and the problem became a HIGH beam won't work problem. Voila! Immediately - probably no ground problem. Maybe still a switch problem - many of you may not know but most GM cars route every light switch through the ER flashers and lots of times that unit fails and takes the lights down.
I did what was obvious to me and checked the other side and found the same pair of relays with a really poor job of wiring one relay connector on the passenger side. It may have been a factory issue and was good enough to get the car 6 years down the road and reduce warrantee expense to zero - or it could be the previous owners work as he installed HID's. Small point. I was able to easily reach the connector, clean up the grunge on the wire, solder it and had low and high lights.
The whole deal took 10 minutes and I consider myself very fortunate. It is an obvious place to check as these lights do get exposed to water and crimped connector is never as good as a soldered one.
Hope this easy fix helps someone else.
Oh, I took the battery out of the multimeter put it back into one of the Christmas toys.
Old Dec 31, 2005 | 06:48 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
Thanks for the post!
It's tips like this that help most of sane.
Happy New Year
Bob
Old Dec 31, 2005 | 08:09 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Good find. Thanks for the info.
Old Dec 31, 2005 | 08:22 AM
DeeGee's Avatar
DeeGee
Congrats and thanks for the post.
Doesn't it feel good when a troubleshooting session is so successful?
I fixed a problem with a fuse blowing on the Camaro yesterday. It made my day. I know just how you feel
To Low Beam problem - FIXED
