Whoever has the install intstructions regardingThe Halo LED's could you please post here or email them to realtimejazz@hotmail.com Thank you When I bought mine they did not come with instructions(off ebay) Mine still blink fast on occasion, but they work normal after the car is driving for a while... maybe I put them in wrong. I think i might of mixed up which light was marked left or right. Mine also are not identical when lit up...the inner lights(towards the license plate) have fewer bulbs lighting up than the outer lights( Two less on each) Are those supposed to go on the outside?
My Halo LED's came with instructions. They were also marked Lt. and Rt. with removable stickers. I'll try and find them later today.
Mine had the stickers as to what LEDs go where (I also think they are stamped on the back if I remember correctly), but no other instructions. Just remove the 2 screws for each light, unplug the connector, remove the sticker covering the pig tail on the new lights, plug them in and screw them back in. I never had an issue with them blinking to fast. They worked as soon as I had them in and flash at the same speed as the old ones. The do light faster when you hit the brake.
Here are some night shots; I have other photos, but not on line.
