Shifter
Old Jan 3, 2006 | 10:34 PM
Gary French's Avatar
Gary French
Default Shifter
If I replace my 6-sp shifter do I have to replace my **** or does it twist off ?
Old Jan 3, 2006 | 10:35 PM
glerma's Avatar
glerma
St. Jude Donor '05
Most aftermarket shifters will accept the stock ****.
Old Jan 3, 2006 | 10:39 PM
Gary French
Default Shifter ****
How does my stock shifter **** come off in an 03 vert ?
Old Jan 3, 2006 | 10:59 PM
vetred's Avatar
vetred
Yo,........Gary,......when you see whats out there you won't want the stock shifter anyway!!!! I took the black anodised "hurst" pistol grip and drilled about 1/2 inch deeper (so it would sit looow) and taped proper threads and I just dig it the most!!!!!!
Old Jan 3, 2006 | 11:01 PM
99VetteM6's Avatar
99VetteM6
http://www.conceptualpolymer.com/corvette_install.htm
Old Jan 4, 2006 | 08:17 AM
dunbindun(tov)'s Avatar
dunbindun(tov)
See http://temp.corvetteforum.net/c5/pat...rInstall.shtml for shifter removal/installation instructions. There are different methods of removing the shift **** key: prying up with screwdrivers/pliers, prying up with two paint can lid lifters, and my method of a makeshift slide hammer using vise grips with a long 1/4-20 bolt & a socket as a slider (pm me if you want more detail). This is the hardest part of the project.
My choice was a C6 shifter, but like exhaust sound, it is a very subjective choice.
DBD
To Shifter
