HELP.. me bust this squeek
Now, the very strange part. It only seems to do it with the engine RUNNING, and it seems to be related to the clutch pedal. I can make the squeeking by pumping in and out the clutch pedal most of the time... BUT THEN it still squeeks if I go over certain bumps, even if the clutch pedal is depressed. Then today in my work parking lot with the clutch depressed I slolumed (sp) back and forth and could make the squeeking happen in tune with each steering wheel turn. If I sit in my seat and bounce around I can make it happen too, but ONLY when the motor is running. If I shut the engine off, I can bounce all around the car, push the clutch pedal in and release it with no squeek. What the heck is this!?
Ive tried using a different roof thinking it might have been one of the latches. Its not the AC blower motor because that also squeeked and I replaced it with a new one $80 later... I also just put in the Crazy Cowboy installation kit, so its probably not some trim floating around either. if I can bust the squeek along with my squeeky drive belts then I'll have a squeek free car. Help!
