Husrt Short throw - Noise?? Reverse???
Old Jan 7, 2006 | 12:50 AM
diyguy's Avatar
diyguy
Default Husrt Short throw - Noise?? Reverse???
I put in a Hurst short throw a week or so ago and love the feel. What a difference.
Now, though the novelty has worn off and am noticing things that need some attention.
There is a significant amount of noise coming up through the tunnel/shifter that wasn't there before. I know the rubber boot doesn't fit but how do I 'engineer' something to quiet it down again?
And, getting it into reverse is a real trick! I almost takes two hands to push it towards the drivers door to find the 'gate' to get it in reverse.
Following directions, I adjusted the springs a little (not more than one turn each on the set screws), but can't detect any difference. SHould I just remove the spring on the right side?
Otherwise a nice mod!
Ideas, opinions and "I stayed at a Holiday Inn Express once" comments welcome
Old Jan 7, 2006 | 01:03 AM
vetred's Avatar
vetred
DIYGUY,...........Um,..eh,......... well the good news is you didnt read the directions,......or,......you didnt believe them! The bad news is you must take the consol off again and do the adjustments,..... (realy) if you didnt use the loc-tight the shift stops WILL move ! Or if you didnt get the asjustments just so,.. the "shift" will not seat correctly you must close your eyes and just FEEEEL the shift! When it seats properly put the screws right on the stop but no further! with a fresh coat of loc-tight on the threads let it sit over night! listen you can do this and your not the only guy to do the whole thing over again !ask me how I know!,..............(dont ask) if I can do this ANYONE can
Old Jan 7, 2006 | 10:18 AM
DirteeDave's Avatar
DirteeDave
For the problem with reverse, I usually throw mine in 1st before going to reverse.
There are several cures for the excess noise issue. The two most popular are to use a half a tennis ball or a rubber PVC end cap with a hole drilled in it and slid down over the shifter. I've tried both and found the PVC end cap to work the best. I recently bought a short shift boot and left the old shift boot installed underneath as another level of insulation as suggested by another forum member.
Old Jan 7, 2006 | 11:07 AM
Patches's Avatar
Patches
You may want to pull the adjust ment setscrews and swap in the softest springs to make shifting easier. I'm only uising the softest inner springs (there are two - on inside the other) with no outers.
AFA the noise, insulation around the tunnel area and the plumbing pipe plug helps a lot. Get the 1-1/2" version of the one pictured below at Lowe's, cut a hole slightly smaller than the shaft in the middle and slip it over the shifter and press it into the isolator as pictured below.
Old Jan 7, 2006 | 04:07 PM
edensknight's Avatar
edensknight
Bingo! Somebody noticed! Out of all the aftermarket short throw shifters I have tried (BBP, B&M, Hurst) I find the Hurst to be one of the best by far, for either my C5's, or, my 60's muscle cars. Make sure you follow the directions. Moreover, add a tennis ball (cut in half), AND, do not remove the o.e. shift boot!! This mod has worked for both my C5's for almost four years now with no issues. Go for it.
Old Jan 7, 2006 | 04:19 PM
captainpooby's Avatar
captainpooby
Great thred. I have a Hurst coming soon and I'll use this advice!
Thanks!
Old Jan 7, 2006 | 04:21 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Old Jan 7, 2006 | 04:47 PM
TEXHAWK0's Avatar
TEXHAWK0
You don't really need any extra pieces. Just trim the stock boot to fit the base of the Hurst shifter instead of reversing it. I marked a circle and trimmed it out with an X-ACTO knife.
Old Jan 7, 2006 | 06:03 PM
edensknight
Great tip option, Patches!
Old Jan 7, 2006 | 06:22 PM
captainpooby
Can you buy that metal backed insulation any where local like lowes?
To Husrt Short throw - Noise?? Reverse???
