From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
Originally Posted by rws.1
I use Simple Green to Clean, my K&N.
I suspect any good General Purpose clenaer would work for you
I've read on this forum in the past that many use a 50/50 solution of Simple Green/water. They say to spray the solution on the outside, let it sit for an hour and then use a water hose from the inside spraying out. That's what ima do when the time comes.
That sounds good but do I need to worry about "re-oiling"? The Blackwing kit comes with the cleaner and the an oil you apply after cleaning it.
If I oil it this time of year and let it sit on some newspaper/towels for a couple of weeks, I assume it would be difficult to overdo the oil? Within reason of course. Do you agree?
If the oil drips, you have applied too much. Spray with a sweeping motion and don't keep the spray can stationary while you are doing this. Still, letting it sit for a while can't hurt anything.
Use Simple Green to clean and K&N oil to re-lube. Be advised that verry little oil is required. Too much oil can foul your MAF sensor wires.
Simple green works well for cleanimg the filter. Be sure to allow the filter to dry completely, and, re-oil any cotton based media filter such as the K&N with K&N oil kit. The Blackwing filter is made of a special synthetic media, and, should be re-oiled with the Blackwing synthetic filter oil.
