Computer "re-learn"
Old Jan 13, 2006 | 02:21 PM
sandmanusd's Avatar
sandmanusd
Default Computer "re-learn"
Well, ever since I installed my Halltech Stinger, I have been getting Check Engine LIght every 3 weeks or so... the codes are lean codes and then the light goes away after about 3-5 days of driving...
Question is.. there was someone on here that had some technique to get the computer to relearn with the current air/fuel mixture, so the engine codes wouldn't return
Some long process or something..
If anyone could share, that would be great
Old Jan 13, 2006 | 02:32 PM
ikaros74's Avatar
ikaros74
Default this might help
http://forums.corvetteforum.com/showthread.php?t=792391
Old Jan 13, 2006 | 02:33 PM
ljthe2nd's Avatar
ljthe2nd
Did you oil the filter before you installed it, if you didn't you will get a check engine light do to dirt getting into the MAF sensor. I don't recal the number right now.
Old Jan 13, 2006 | 02:39 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Careful not to over oil it either because they oil can get on the wire on the MAF sensor and act as an insulator. It will throw a code. Also check that all of your clamps are tight and that air is not leaking in and causing it to go lean. Spray carb cleaner around all the joints and see if your idle changes. If it does them you have a leak. You would be suprised how often we see this at my shop.
Old Jan 13, 2006 | 02:43 PM
sandmanusd's Avatar
sandmanusd
No I didn't, I wan't aware that you had to.. it felt greasy when I took it out of the package.. I assumed it was oiled...
Do they not come oiled out of the box?
Old Jan 13, 2006 | 02:44 PM
sandmanusd's Avatar
sandmanusd
Very cool brother.. thanks.. thats the thread I was looking for!
Old Jan 13, 2006 | 07:03 PM
ljthe2nd's Avatar
ljthe2nd
When I bought a new Halltech Stinger, (about a year and a half ago) it did not come pre oiled. I know most K & N stock filter replacements and Mr. Gasket, KOOL BLUE replacement filters do come pre oiled, the couple of aftermarket performance filters I've bought have not come pre oiled. I use the K & N recharge kits for filters with a red color to them, and Mr Gasket also makes a recharge kit for their filter and their oil has a blue tint to it so I use their kit on blue filters. Just spray a light coat on the filter, just enough to see a slight color change in the filter, but don't put to much on as RichieRichZ06 points out as that can cause problems also. You do not want to see any oil dripping off the filter, if you do you have way to much on it. Just take the filter off, clean it, oil it, and reinstall it. Then clear the codes using a Programmer, or some other method that people have suggested and you should be fine.
Old Jan 14, 2006 | 05:14 AM
MrLeadFoot's Avatar
MrLeadFoot
If it's greasy and red, it's oiled. (Might not be red, though, could be a different color)
To Computer "re-learn"
