[Z06] Miles on Clutch
Old Jan 16, 2006 | 06:16 AM
1FunZ06's Avatar
1FunZ06
Default Miles on Clutch
How many of you replaced the clutch? At what mileage?
What kind of condition was it in? Did it need to be changed?
Old Jan 16, 2006 | 08:15 AM
Ranger's Avatar
Ranger
You can think of clutch life like you think of brake life. They are wear parts whose service life depends on how they are used.
By far the most common issue with a clutch in a Z06 is pedal woes, aggravated by cooked clutch hydraulic fluid. Once pedal woes manifest themselves, about the only solution is to change out all the clutch parts, including the hydraulics.
I never had pedal issues with my 2002 Z06. But I did replace the clutch after about 175 launches. The wear on the pressure plate and rotating disc was very even and had probably another 30-50 launches left in them. I replaced them anyway and derived no benefit to the performance of the car. That experience told taught me that the clamping power of the clutch will remain pretty constant until the friction surfaces are essentially worn out.
Bottom line is that unless you are launching the car a lot, the stock clutch should last many, many miles, certainly way beyond the 36K warranty. If you do launches, you can expect about 175-225, assuming a fast clutch release without much slip. If you do high-rpm clutch dumps, then expect 50-75 per clutch.
Ranger
Old Jan 16, 2006 | 10:12 AM
SnowyATX's Avatar
SnowyATX
Here is another data point. I just changed out my stock clutch in my H/C Hardtop at 42K miles for the LS7 clutch. The H/C has been in for 15K or so. I don't take it to the track but I have "attempted" a hard launch or two with nothing but clutch smoke.....i.e. my stock C5 clutch couldn't handle the power. The clutch help up great as long as I didn't try to launch hard. I probably could of left it in for quite a while longer but I had the itch to replace it and do some gears at the same time. There are some pics of the clutch in this link if your interested.
Old Jan 16, 2006 | 10:23 AM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
65K miles, stock clutch
...but I don't drag race
Old Jan 16, 2006 | 10:29 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
45k stock clutch, had about 7 1/4 runs on the car, do mostly HPDE and auto-x which doesn't tax the clutch.
Swapped it out because the rear/trans had to come out to fix a differential moan under warranty so I only had to pay $100 in labor and that was b/c I had LT headers on the car.
Tech said the clutch looked great, I have it in my shed. Now running a LUK stage II with the fidanza aluminum flywheel. Have almost 53k on the car now.
Old Jan 16, 2006 | 09:40 PM
1FunZ06's Avatar
1FunZ06
Ranger
I've got 64K on my car and still have good clamping power.
Thanks to all for your feedback. Just wanted to get some idea when to have it checked.
For those that have had it done, what's the approx cost?
Thanks!
Old Jan 16, 2006 | 09:42 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Did I understand you right?
You had 15K on your stock clutch after your H/C went in ?
My stock clutch has 18000 miles on it. I have the TR224 cam and it holds fine during a little harder than normal use. The only time it had an issue was I was racing a motorcycle and went from 2nd to 5th and it slipped. I figure when I get the AFR 205s put on, Id go with the LS7 set up
Old Jan 16, 2006 | 09:46 PM
chiefDave's Avatar
chiefDave
St. Jude Donor '05-'06
Ranger
Ranger you got your new Z on the way??? Awesome brother and I am sure many of are waiting to see what you will do bone stock with it... 10s anyone? Awesome brother and congrats!
Oh back to the post... replaced mine @ 30k, and did have some sluch at the track, 1/4, maybe 50 passes. Using the techniques above (well trying) and it had much more left in it, but it was worn pretty well. Moved to an Aussie, and love it. Maybe 40 more passes on it and it gets better each pass. Smoothed out and has no fade at all after we wrapped the pines and changed to motoul 600 fluid. I drove 200 and ran it hard at the track the next day and it took it, became more linear, and feals better than stock IMO. Hope this helps.
Dave
Old Jan 17, 2006 | 02:13 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Just turned 15k, but only 2k since all the mods. Smoked the stocker last weekend trying to practice launching, but that was expected with the boost in power. Now looking into the LS7 setup.
To Miles on Clutch
