oil consumption
Old Jan 16, 2006 | 07:43 PM
gillettij's Avatar
gillettij
Default oil consumption
The picture that you see there to the left was my 2000 coupe. I sold it and you guys have convinced me to go with the vert next time. Now that's settled, my question is; which years consume oil, and which don't?
Thanks in advance for all of helpfull information.
Old Jan 16, 2006 | 07:50 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Sorry to see the MY coupe go, but good luck finding the vert. Some of the late '00's and the early '01's are more widely recognized as the oil consumers. All can use some oil under ahhemm, "spirited driving"
Paul
Old Jan 16, 2006 | 07:52 PM
DeeGee's Avatar
DeeGee
Thats what I'd read here. The 01s and earlier could use a little oil at times.
I've had no troubles with my 02. Rarely need to top it up between changes.
Old Jan 16, 2006 | 08:06 PM
Patman's Avatar
Patman
Actually it seems to be the other way around. Anytime there is a survey the 2001-2004 engines tend to burn more oil than the 1997 to 2000 engines.
My 1998 uses no oil at all, even when I just finished up a 9000 mile run on the same oil, the level on the dipstick was unchanged the entire time!
Old Jan 16, 2006 | 09:29 PM
RonJ's Avatar
RonJ
My 01 with 30,000 miles doesn't use oil!!
RonJ ...
Old Jan 16, 2006 | 09:32 PM
LiquidDI's Avatar
LiquidDI
my early 00 eats oil. Some do some don't. Doesn't matter what year
Sillyme's Avatar
Sillyme
my 04 hasn't used any oil yet.
Old Jan 16, 2006 | 09:36 PM
troy144's Avatar
troy144
Old Jan 16, 2006 | 10:03 PM
steve8's Avatar
steve8
Same here.
Old Jan 16, 2006 | 10:11 PM
BarneyZ's Avatar
BarneyZ
My '00 burned 1.5 quarts between 3k oil changes when new. 31k miles later she doesn't burn a drop! Took a long time for the rings to seat, I guess.
Old Jan 16, 2006 | 10:22 PM
C5Jimmy's Avatar
C5Jimmy
According to a Corvette Magazine article, #17, May 2005, they say '99-'02 LS1's and LS6's Says happens to cars that are regualrly revved high, aka"spirited driving".!! ( I guess thats 99% of us! )More common in MN6's...
The #2 compression ring and oil-expander rings are the culprit.
I have an '00 FRC...so far so good!
(I'm also installing a catch can soon...)
Old Jan 17, 2006 | 07:19 AM
Oil consumption was a problem in the '01 model year, especially with the manual transmission cars. However, my '00 had the problem too.
Old Jan 17, 2006 | 08:04 AM
Fourtrax250R's Avatar
Fourtrax250R
my 99 used a litlle, but my 01 has never used a drop!! so I guess its a hit or miss thing? good luck!!
Old Jan 17, 2006 | 08:20 AM
Cajun99's Avatar
Cajun99
I change my oil every 5-6K miles and always check the dipstick in the interim. Virtually never see any usage by the time I change it.
This car gets plenty of spirited driving every week...that's why I own Corvettes
Old Jan 17, 2006 | 08:34 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
'01 vert here ... > 30k and never has used oil.
Oil consumption seems to vary and is not an issue on every car of any model year.
Old Jan 17, 2006 | 09:04 AM
MisterC's Avatar
MisterC
RonJ ...
My 01 has 40,000 and no oil issues. I'm beginning to think the 01's are getting a bum rap. Mine is a great car and we do push the envelope occasionally.
Old Jan 17, 2006 | 11:38 AM
mrC5er's Avatar
mrC5er
MisterC......are your wheels the originals? Reason I ask, is that my 01 coupe has the thin-spoke polished ones, that I believe are original. I know GM changed from one type to the other, but did they do it during mid-year 2001?
To oil consumption
Old Jan 17, 2006 | 01:56 PM
Sorny's Avatar
Sorny
Those look like magnesium wheels to me, they are definitely not thin spokes...
I think the change was sometime on '00, not '01.
As to the oil consumption issue, I add about 1/4-1/2 quart every 8000 miles, with considerable "spirited" driving (I capture about 2oz in the catch-can during the same interval). I've got a '00.
Sorny
Old Jan 17, 2006 | 02:03 PM
Timsvette's Avatar
Timsvette
Thats due to the use of synthetic oil from the factory... Rings seat within 250 miles when you break in using Dino oil... Then just switch over to Syn after break in...
Old Jan 17, 2006 | 02:06 PM
JCR_Indy's Avatar
JCR_Indy
Same here! BUT, I only put 3K miles a year, so there!
JCR_Indy
