glass TOP CRACKED! EEEKS????
Old Jan 16, 2006 | 08:43 PM
korvette4u's Avatar
korvette4u
Default glass TOP CRACKED! EEEKS????
I found two small cracks on either side of the top...Can the top (plastic/glass) be repaired? or will a new top need to be purchased?
Old Jan 16, 2006 | 08:47 PM
jrose7004's Avatar
jrose7004
Yes they can be reskinned! www.astrotops.com
Old Jan 17, 2006 | 12:20 PM
shannanl's Avatar
shannanl
I just called them. They charge $550.00 if the frame is in good condition. They can send you one with a $250.00 core charge and then you send yours back to them. He did not say how much extra it is if the frame is damaged or if they even will take a damaged frame. They don't use the OEM glass, they use a replacement that he said will not crack or peel.
Shannan
Old Jan 17, 2006 | 12:46 PM
Hammie's Avatar
Hammie
I wouldnt go that route then, I think one's for sale brand new on here for like 600.
Mark
Old Jan 17, 2006 | 12:49 PM
Hammie's Avatar
Hammie
Found it:
http://forums.corvetteforum.com/show...94&forum_id=53
To glass TOP CRACKED! EEEKS????
