*Wind deflector *
Are you talking about my bottle of Scratch X on the cowl or the space between my wheel/fender??? I had to get the BSM shadow off, mang!
All good mang!
It also redirects some air around the side of the car, and once you hit 60 mph, you REALLY notice the wind noise bouncing off the outside pillars right behind your ears.
The fit is also something to be desired, as is the attachment design.
Needless to say, I returned it in a heartbeat.
I've always been suspect of the hatch vents, but tired of not being able to drive more than 30 mph in my coupe with the top off, in desperation I contacted the inventor of the rear hatch vents that prop the hatch open 1.5".
This guy was an engineer for 40 years, and guarantees that you'll be happy...period. When I asked how long the guarantee was, he alluded to "forever". He said that he owns the patents on these vents. I checked his pricing, and he was cheaper than any of this distributors, mostly because he doesn't overcharge on shipping.
Thinking I had nothing to lose but time....again.... I ordered a set. All I can say is WOW!!!! These things are the cat's meow.
Contrary to what you might think, they do not cause more air to travel through the car; they simply give any air that enters the cabin a place to go, instead of buffeting around inside the car. During my testing I even drove around with a small piece of paper the size of a receipt on the passenger seat to see if it would get whipped out of the car. With the windows up at 70mph, the paper didn't move at all.
Somehow, no exhaust comes in the car, either, thank heavens.
I can go as fast as I want now with the top down, and STILL hear the radio. I can drive at freeway speeds and still use my cell phone with my headset.
Don't waste your money on shipping to and from trying the Windjammer, just get the hatch vents. You won't be sorry.
The name of the company is Ventmaster. You should order direct. http://www.ventmaster.net
My apologies to the folks that make the Windjammer. Probably works well for Verts, but not nearly as good as the hatch vents on coupes.
Windjammer actually helps Ventmaster maintain its price point, because the Ventmaster hatch vents at $70 seems cheap compared to $200 for the Windjammer that doesn't work, even if the Windjammer does utilize much more material in its construction.
