MAF plug
Old Jan 18, 2006 | 04:59 AM
JTAllen79's Avatar
JTAllen79
Default MAF plug
WTF! How do ya get this off with out breaking it ? Thanks.
Old Jan 18, 2006 | 09:09 AM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I don't remember exactly, I do remember it will **** you off until you figure it out though.
I believe that you have to pull out the retaining clip and then you will have a tab to release to seperate the two pieces.
I'm sure that someone will chime in with some pics that will illustrate it for you soon.
Old Jan 18, 2006 | 09:13 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi John -
WTF? Why are you fiddling with your maf plug at 4:00 am?
You have to pull the white plastic locking piece out first, then you can remove the plug from the maf.
You should have called me last night.....
best regards -
mqqn
Old Jan 18, 2006 | 01:07 PM
JTAllen79's Avatar
JTAllen79
Originally Posted by mqqn
Hi John -
best regards -
mqqn
I was messing with it late last night. I'm going to change the air filter and I want to remove the entire assembly to do some cleaning in there.
Old Jan 18, 2006 | 02:35 PM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Cool -
Just look at the plug - there is a white lock thingy that is stuffed in the plug - puill it out and then it will come off.
Wow - not sure about your drain of the coolant -
Call grim and ask -
Also - just drive to Fl and we'll all change the diffs out together - we'll get the stuff the EG recommends - pizz on that $27 chizz......
I have darts tonight - you need the manuals?
best regards -
mqqn
Old Jan 18, 2006 | 02:52 PM
JTAllen79's Avatar
JTAllen79
Naw, I'm cool, thanks. I just want to try to get as much of the coolant out as possible.
Old Jan 18, 2006 | 10:08 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Yep.
Old Jan 18, 2006 | 10:12 PM
mowton's Avatar
mowton
I had the same problem, but the experts from the forum got me through it as well. Thank God for the Corvette Forum members and Digital Cameras. This place is great
Old Jan 19, 2006 | 01:28 AM
SLPRC5's Avatar
SLPRC5
Originally Posted by Mr. Lucky
Yep.
I think I lost mine
To MAF plug
