climate control problems
Old Jan 20, 2006 | 01:47 AM
sting072's Avatar
sting072
6th Gear
Default climate control problems
I have the dual zone climate control. It will only blow hot air on the passenger side. On top of that it is blowing from all of the vents at the same time.
I pulled fuse #27 and disconnected the battery, but it didn't help. I pulled the codes and I am showing B0361 H, B0363 H, and B0441 C H.
I cleared the codes but they come right back.
thanks
Old Jan 20, 2006 | 04:44 AM
sebringsilver97coupe's Avatar
its broke.
TTT for ya till someone w/more in depth diagnostics help can reply.
Old Jan 20, 2006 | 10:57 PM
Der Flieger's Avatar
Der Flieger
Default Hvac
There is a procedure for re-programming the mixture valves,-failing that, you may have a vacuum line damaged by battery acid near the PCM. Also, the HVAC control head may need an overhaul. There is a vendor here on the Forum who does good work on them. Start with the re-program. It's in the Helms manual. Good luck!
To climate control problems
