O-Ring for Tire Pressure Sensor???
Old Jan 20, 2006 | 11:39 AM
roscoe118's Avatar
roscoe118
Default O-Ring for Tire Pressure Sensor???
Have any of you found a replacement part for this? I just spoke with a local Chevy parts department and they tell me that you can only get them when you buy the entire sensor
I have a slow leak on one wheel and am about to have the tires replaced. I would like to fix this at that time, but don't want to have to replace the TPS.
A search did not really answer this question.
Old Jan 20, 2006 | 11:48 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
They are standard everyday o-rings. When I swapped my wheels, I went into my o-ring box and pulled out a few different sizes. They are a little thicker, but they work 100% fine.
If you want, PM me your address and I'l mail you a handfull.
Jeff
Old Jan 20, 2006 | 11:49 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Not long ago someone said you can get them at Home Depot. I believe it's a #9 O-ring. Worth a try.
Old Jan 20, 2006 | 11:53 AM
roscoe118's Avatar
roscoe118
Jeff
Thanks Jeff I love this place
johnandsarah002's Avatar
johnandsarah002
I replaced mine with the #9 o-ring from Home Depot last Oct. No problems so far
Old Jan 20, 2006 | 12:03 PM
roscoe118's Avatar
roscoe118
Thanks, as well, Eddie and John
John, BTW, I have a brother John and his wife's name is Sarah
Old Jan 20, 2006 | 12:48 PM
poolhustler's Avatar
poolhustler
I also have a slow leak in one tire. Where does the o-ring go? Is it inside the tire? Is so, my leak may require a different fix.
Thanks,
Russ...
Old Jan 20, 2006 | 01:07 PM
Good to know.
Old Jan 20, 2006 | 01:34 PM
roscoe118's Avatar
roscoe118
Thanks,
Russ...
Russ,
The o-ring is inside and is the "gasket" that seals the base of the valve stem to the rim on cars with the TPS system. They have been prone to leaking. I guess they dry out or something.
You can try tightening (slightly) the nut at the base of the valve stem, at the rim. Or it could be the valve stem itself. There is tool to use to tighten the valve inside the stem.
Good Luck
Old Jan 20, 2006 | 01:56 PM
Hammie's Avatar
Hammie
Roscoe118, they lied to you. I JUST bought 4 o-rings from my CHEVY dealer specifically for the TPS sensors. They sell them.
Go Steelers.
Old Jan 20, 2006 | 02:37 PM
Allzwell's Avatar
Allzwell
St. Jude 15 Year Donor
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
I've done the replacement before ... no problem.
Old Jan 20, 2006 | 02:38 PM
OUR97's Avatar
OUR97
I replaced all 4 with the Home Depot ones. Been good for a year now. So they do work.
Old Jan 20, 2006 | 02:39 PM
troy144's Avatar
troy144
Old Jan 20, 2006 | 03:03 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Does he own a Vette? Maybe you're related!
Old Jan 20, 2006 | 03:35 PM
mschamberger's Avatar
mschamberger
I ordered a whole new set from GMPARTSDIRECT.COM, the part# is 25715243.
Old Jan 20, 2006 | 04:02 PM
wit2pz's Avatar
wit2pz
Guys, before you go tearing the tire off the rim to replace this gasket, check into this...
I had a slow-leaking tire a few months ago, on my right rear tire. I had to refill it just about ever 4 or 5 days. The last time I went to fill it, I rubbed my finger across the valve stem and heard a faint-yet-noticeable hiss.
I found that when I purchased my C5 Logo valve caps, there is a small rubber gasket inside that, when the cap is on tight, is supposed to fit in around the valve. This thing was pushing the valve slightly to the side, just enough to cause the leak.
I removed it completely and pulled gently on the valve to get it to seal. It worked. Haven't had a leak in 3+ months.
I had to use tweezers to pull the gasket out of the end of the stem.
Hope this helps.
Old Jan 20, 2006 | 04:03 PM
wamara's Avatar
wamara
Cruise-In II Veteran
roscoe118,
Just so we're clear, are you talking about the "old" style sensors or the "new" style sensors (97-99 and 00'-2004 respectively(I think))? My understanding is the old style used a simple o-ring; the new style has a fancy "stepped" design that is pretty unique - I doubt you'd find those at your local hardware store. To the two people who posted about getting them from the dealer and gmpartsdirect, can you clarify for what model year/what style these were replacing? Thanks.
To O-Ring for Tire Pressure Sensor???
Old Jan 20, 2006 | 04:19 PM
Hammie's Avatar
Hammie
Originally Posted by wamara
roscoe118,
For my 99 vert early style sensors, GM carried the o-rings. Spent about 7 bucks for all 4.
Old Jan 20, 2006 | 04:21 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Check some of Discount Tires, they may have.
They are the same for BBS wheels.
-Mike
Old Jan 20, 2006 | 04:26 PM
roscoe118's Avatar
roscoe118
roscoe118,
This is interesting. I know that there are differences in the old/new sensors but did not know the o-rings were different
For those of you that say you replaced them with the #9 ring from Home Depot, do you have the old or new style sensors?
mschamberger, do you have an 00' or newer car? Thank you for the part number. If these are for an '00 or newer car (I have an '02) I'll try calling the parts department back.
If anybody has used the #9 rings on an '00 or newer car, please chime in, I'd much rather do that than pay the "Corvette Tax" on a GM part
