O-Ring for Tire Pressure Sensor???
Old Jan 20, 2006 | 05:53 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Old Jan 20, 2006 | 06:38 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
There appears to be a difference in the way GM has handled this.
The o-ring for '97-'00 is p/n 10268438 and was a stocked item for replacement
The o-ring for '01-04 is listed without a part number and is packaged with the sensors and the nuts.
Here is a photo of the early sensor
Here is a photo of the newer sensor.
There is a clear difference in where the o-ring would go.
Paul
Old Jan 21, 2006 | 12:09 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Paul
Paul, not sure what you mean in your last sentence, as the ridged, black "ring" around the base of the valve stem (of the new style sensor) IS the "o-ring" which seals the TPS against the inside of the wheel rim.
Old Jan 21, 2006 | 02:22 AM
poolhustler's Avatar
poolhustler
Originally Posted by wit2pz
Guys, before you go tearing the tire off the rim to replace this gasket, check into this...
I had a slow-leaking tire a few months ago, on my right rear tire. I had to refill it just about ever 4 or 5 days. The last time I went to fill it, I rubbed my finger across the valve stem and heard a faint-yet-noticeable hiss.
I found that when I purchased my C5 Logo valve caps, there is a small rubber gasket inside that, when the cap is on tight, is supposed to fit in around the valve. This thing was pushing the valve slightly to the side, just enough to cause the leak.
I removed it completely and pulled gently on the valve to get it to seal. It worked. Haven't had a leak in 3+ months.
I had to use tweezers to pull the gasket out of the end of the stem.
Hope this helps.
Yep!!!!!!! I checked mine and the small o-ring inside of the aftermarket caps was puching down on the inside of the valve stem and letting air leak out.
Thanks!!!
Russ...
Old Jan 21, 2006 | 02:33 AM
99FewteRC5's Avatar
99FewteRC5
Paul
the seal on the newer sensor is the same as regular steel screw on type valve stems that you can get at the local parts store. You can also replace it onto the older style sensor.
Old Jan 21, 2006 | 02:37 AM
wamara's Avatar
wamara
Good to know !!
