Build date
Old Jan 25, 2006 | 07:34 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Guys if still need the information, Please PM me your vehicle number. Posting it on the board gets to be a bit much.
Old Jan 25, 2006 | 10:59 PM
GrayC5's Avatar
GrayC5
Originally Posted by reb854
your buildsheet is located inside the front metal rebar inside the front bumper normally on the drivers side, you can take the lower splashield off under the bumper and reach it. This sheet will tell you everthing as far as options. etc.etc. most of it is coded. yor local dealer can disect the vin for you as well good luck!
Originally Posted by troy144
Hi. You know what I did... I went to the National Corvette Website and went to build sheets. They sell this laminated, and a reproduction laminated window sticker. It is not cheap but they look good, like a dinner mat. I think I spent like 60 bucks. It took like two weeks to get but they look good, if you are going blow some money I guess it is worth it. I did. Hope that helps, it is a rip if you go this route but hey it's a Corvette.
The build sheet is a very nice piece of documentation to have, especially for the Corvette enthusiast. However, the build sheet does not show the build date. Keep in mind that the build sheet is produced sometime prior to the build start and accompanies the vehicle down the assembly line. The printed date in the upper right hand corner of the build sheet is the proposed target production date, not the actual build date.
One of the best ways to find the actual build date is to have a dealer or one of the Forum members here like Sponge Vette who have access to GM's Vehicle Inquiry System (VIS) inquire the system for the build info. This portion of the VIS information will show the actual build date.
Hope this helps.
