[Z06] '03 Z06 question
Old Jan 22, 2006 | 05:38 PM
hotwheels57's Avatar
hotwheels57
Default '03 Z06 question
Can anyone tell me if this VIN (1G1YY12S335123002) is an "early" or "late" production model. How do you tell from the sequence?
Thanks in advance.
Old Jan 22, 2006 | 06:23 PM
Andy64's Avatar
Andy64
Try this site:
http://www.corvetteactioncenter.com/...003/index.html
Probably won't help much as they dont list the upper number produced and the serial number series include all C5's. However, lots of good info regarding all C5's. Last 6 of the VIN is the series sequential numbers. Supposedly they start with 100000 and 8635 2003 Z's were produced (total of 35,469 C5's produced in 2003). Its hard to really tell because its impossible to tell how they run in relation to all C5's that were produced, but I would say it appears it would be somewhere in the 2nd half of the year.
Old Jan 22, 2006 | 06:32 PM
IT L GO's Avatar
IT L GO
"late" production model with steel shift forks and the FFS fuel system
Old Jan 22, 2006 | 06:35 PM
hotwheels57
Thanks to both of you. IT L GO, are you saying that VIN would indicate it is late production with those improvements?
Old Jan 22, 2006 | 08:35 PM
Scott03Z06's Avatar
Scott03Z06
The FFS fuel system is easy to determine...just open the glove box and look and the ID label fro the RPO FFS. As far as I've been able to determine, the steel shift forks were a mid-03 change.
I'd sure like to know the exact VIN the steel shift forks started at.
Old Jan 22, 2006 | 08:39 PM
slong's Avatar
slong
Old Jan 23, 2006 | 01:03 AM
Bill Dearborn's Avatar
Bill Dearborn
It it helps my car has a 109473 number and it was built in October 2002.
Bill
Old Jan 23, 2006 | 09:32 AM
IT L GO's Avatar
IT L GO
Yes
Old Jan 23, 2006 | 09:33 AM
IT L GO's Avatar
IT L GO
Me too! All I know is it was sometime in Feb. 2003 for the shift forks. Some of the early FFS cars didn't get the Label in the glove box
More info on the FFS Fuel System at this link
http://www.z06vette.com/forums/showt...&highlight=ffs
Old Jan 23, 2006 | 09:00 PM
RC5's Avatar
RC5
Check the left door lock area for a Manufactures sticker...It'll have a month of production left upper corner. Like MAR 2003 etc.
Good Luck
Old Jan 25, 2006 | 11:37 AM
electra's Avatar
electra
My 2003 Z has a 'Born On' date on the drivers' side door. Check there if you don't find what you need from the VIN.
Old Jan 25, 2006 | 12:08 PM
hotwheels57
That makes it much simpler, thanks...I'll do that.
Old Jan 25, 2006 | 06:39 PM
Swiftwater Z06's Avatar
Swiftwater Z06
Would anyone care to briefly explain to a new Z06 owner what these two issues "steel shift forks and FFS fuel system" are all about?
Old Jan 25, 2006 | 07:28 PM
Scott03Z06's Avatar
Scott03Z06
FFS is the new fuel system that was introduced in mid-03 and is also present on the C6. Go here to read the details http://service.gm.com/gmtechlink/ima.../TLMar04e.html
The B&W T56 6-speed (MN6 and M12 (Z06 specific)) had cast Alum. shift forks prior to approx. mid-03 production. I assume the many complaints about the shifter being stuck in a certain gear and syncro problems and subsequent teardowns of these transmissions revealed the Alum. shift forks were a weak link. They were then replaced with steel shift forks. Note that the Viper, which also uses a T56 tranny, has steel shift forks. It was probably a cost cutting move to use a cast Alum. shift fork over the steel shift fork.
Old Jan 25, 2006 | 10:07 PM
Swiftwater Z06
Thanks for the explanation.
Old Jan 27, 2006 | 10:50 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Weight savings not money
Old Jan 31, 2006 | 12:00 PM
4CEE's Avatar
4CEE
Is there a disadvantage with the cast aluminum shift forks that I should be aware of?
To '03 Z06 question
