siphoning gas
Old Jan 23, 2006 | 11:10 AM
Yoggi's Avatar
Yoggi
Default siphoning gas
No I'm not looking to beat the high gas prices!!!!!
There is an upcoming indoor show that I want to attend. They will only allow 1/4 tank of gas in the car. Has anyone had any problems siphoning gas from a c5? Will the siphon tube fit all the way down the filler to the tank?
Old Jan 23, 2006 | 11:24 AM
tiojames's Avatar
tiojames
Default gas
How about undoing the fuel line up front and using the fuel pump to get the extra gas out.
Old Jan 23, 2006 | 12:47 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
or if you have access to a lift, unbolt the fuel pump and go that route, i did that to install a pump, just make sure you have something to catch it, or drive your car around for a while
Old Jan 23, 2006 | 12:54 PM
NSTG8R's Avatar
NSTG8R
WOTTT . .. WOOTTTTT ... WOOOOTTTTT ..
guess which option id select. hehe
... you cant siphone all the gas out through the filler neck due to the two gas tanks.
Old Jan 23, 2006 | 01:20 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
35 or 40 burnouts will do the trick
Old Jan 23, 2006 | 01:25 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
Who'd a thunk?
Old Jan 23, 2006 | 01:43 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
If your profile is up to date, you should know what driving is like in GA. If I want to run my car out of gas here in this state, I just get onto a main roadway. Traffic is always messed up like a football bat here and you can't get any gas mileage when you're in a constant state of slowing down. You shouldn't have any problems.
Old Jan 23, 2006 | 01:53 PM
jman1's Avatar
jman1
Old Jan 23, 2006 | 02:02 PM
Ghost Vette's Avatar
Ghost Vette
Yoggi, take it down town Atlanta and leave it for and hour or so. Someone will remove it for you. hahaha!!! Hope to see ya soon in Fayetteville.
Old Jan 23, 2006 | 06:17 PM
I agree - may be hard siphoning it out from dual tanks. Best to either drive it around until it gets down to the desired level or unhook a hose.
Old Jan 23, 2006 | 06:24 PM
Yoggi's Avatar
Yoggi
Hi Bob, look forward to seeing you this spring.
To siphoning gas
