[Z06] PIAA Driving Light Replacement - Help
Old Jan 25, 2006 | 04:55 PM
AFVETTE's Avatar
AFVETTE
Default PIAA Driving Light Replacement - Help
One of my PIAA Driving Light's just failed. I ordered a replacement bulb/lens ($48 Holy Cow but that's another post) and I need a quick tutorial on how to replace just the bulb/lens assembly?
Tom
Old Jan 25, 2006 | 06:01 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Yeah the bulbs are pretty expensive.
Replacement is quite easy.
Just remove the lamp assembly from the car. Then there are two screws on the outside of the housing that you must remove. At this point, the front lense can be removed from the housing. Then you remove 3 small screws from the inside of the lense. Then the bulb can be removed and replaced.
Old Jan 26, 2006 | 06:10 AM
AFVETTE's Avatar
AFVETTE
Got it thanks. As I recall it should be easier to go in from the service panel. So I'll need to wait until I can get on my buddies lift.
Tom
Old Jan 26, 2006 | 09:55 AM
DPG's Avatar
DPG
St. Jude Donor '06
make sure you dont touch the bulb with your fingers, use a paper towel or something so that you dont get and oils on it.
Old Jan 26, 2006 | 12:22 PM
Z06ufgrad2002
Actually, it is not possible to touch the bulb. It comes premounted in the glass lense.
Old Jan 26, 2006 | 04:14 PM
DPG's Avatar
DPG
St. Jude Donor '06
ahhh, is that why the price on em is a little higher?
Old Jan 26, 2006 | 05:17 PM
AFVETTE's Avatar
AFVETTE
Yup that explains the $48. Thanks to all that responded. I sold my Z and the bulb just burned out. I didn't want to sell it with a burned out bulb.
Tom
Old Jan 27, 2006 | 04:59 PM
DPG's Avatar
DPG
St. Jude Donor '06
Tom
Its the little things that make a sale go good or bad a lot of times. Nice to hear that you are doing this when you already sold the car and didnt really have to do. Your a standup guy
To PIAA Driving Light Replacement - Help
