oil change
Old Jan 27, 2006 | 09:44 AM
TEXHAWK0's Avatar
TEXHAWK0
I used to change my oil every 3,000 miles, but now I go by the oil life monitor, which usually shows it needs to be changed between 3,500 and 4,500 miles.
I went 5,000 miles once and had the oil analyzed. The analysis showed the oil still had plenty of additives left and could have gone a few thousand miles more. New oil has a total base number (TBN) of around 12, and my oil still had a TBN of over 5. A TBN of 1 would be about the lower limit.
Old Jan 27, 2006 | 12:32 PM
c-5-steve's Avatar
c-5-steve
This is one time when letting your DIC do the thinking wont get you in trouble
Old Jan 27, 2006 | 12:40 PM
jrose7004's Avatar
jrose7004
Originally Posted by c-5-steve
Do what the DIC says or once a year
Listen to your DIC!
Old Jan 27, 2006 | 02:11 PM
edensknight's Avatar
edensknight
Every 3K with Redline 5W30.
Old Jan 27, 2006 | 02:27 PM
rws.1's Avatar
rws.1
GM put a lot of effort into the algorithms behind the oil monitor system and stakes their warranty on it.... why would anyone question it????
Change your oil once a year or when you get down to 10% of remaining oil life and you will be absolutely fine.
Mobil 1 5W30 or any other synthetic 5W30 that meets the GM test will do.
