oil change
Old Jan 26, 2006 | 10:26 AM
jlacomb's Avatar
jlacomb
Default oil change
How often should I change my oil? Should I trust the computer, are should I just change it every 3,000? Also, what type of oil do you use?
Old Jan 26, 2006 | 10:29 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
the computer is ok, but driving style is a better indicator
I change my oil every time I go to the track. some say that is over kill, but heck it doesn't cost that much and I feel better.
If you only drive your car a few miles per year then I would change the oil in the late fall before storage and then again in late spring after you used it.
Normal driving I would use the computer.
BTW - I use Mobil1 5w-30
Old Jan 26, 2006 | 10:32 AM
Tom/99's Avatar
Tom/99
I change the oil and filter every 2,500 miles. lately, that's about every 6 months.
Old Jan 26, 2006 | 10:37 AM
Ginzo's Avatar
Ginzo
There has been alot of posts on this subject and they have made a believer out of me. I run the oil life counter almost to zero. The manual says if you don't run out it out then as a minimum change your oil once a year.
Old Jan 26, 2006 | 10:45 AM
Tom337's Avatar
Tom337
I change my oil once a year,thats about every 5 thousand miles.I change it just before I put it away for winter.The oil usage on the DIC says around 50% used.
Old Jan 26, 2006 | 11:29 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Follow the manual, but at least once per year, and if you drive in a dusty area, remember manual then suggests changing at 3k (as the Oil Life Monitoring system cannot detect dust).
Use Mobil-1 oil and the Mobil-1 Oil Filter too.
If your temperatures NEVER drops below zero (farenheit), you could use 10w30, otherwise 5w30.
Old Jan 26, 2006 | 11:40 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Old Jan 26, 2006 | 12:18 PM
F355FTS's Avatar
F355FTS
Cruising
Default Here is the low down
C5 corvettes use mobile1 synthetic oil. Which recomened changes are at 15,000 miles thats what the computer figures up or down on how you drive. Same goes for porsche's. New oil technology the old 3000 mile rule does not apply unless your not using the right oil.
The computer is dead on accurate unless you are in some sort of weird extrem conditions which very few people actually are. If you drive less then 10k miles a year. Just change it once a year. Walmart 5 quart container 5w30 is around $29 bucks here.
Roger roger
BIG 10 4
Old Jan 26, 2006 | 12:28 PM
Billdog350's Avatar
Billdog350
The filter looks easy as hell to replace on the C5 so I'm planning on continuing what I was doing on my LT1 Camaro. I was going 2500-3000 and then changing the filter and topping off the oil (usually approx 1 qt) and then changing oil and filter at 5000-6000. The problem is not the oil breaking down as much as it is the filter getting clogged and/or the oil building up residue and deposits. I have talked to a few people and it seems like normal/slightly aggressive driving will give you a 10,000 mi oil change interval according to the computer. I just bought the car but I'm at 58% now and I plan on changing everything, resetting and going from there.
As a side note, the LT1 Camaro had 160,000 miles on it when I sold it after having Mobil 1 from day one.....compression was still perfect, the car was putting down 270hp to the wheels (just exhaust and K&N filter done to it), and it didn't burn a drop of oil. I'm hoping my C5 is the same way.
Old Jan 26, 2006 | 12:40 PM
thisMSGgood4me's Avatar
thisMSGgood4me
I do the very same thing for the very same reason.
Old Jan 26, 2006 | 12:48 PM
I use Mobil 1 5W30 fully synthetic oil. I change mine normally about once a year since I only put about 4000-5000 miles a year on it. If you drive it more, just follow the DIC and change it when it shows a low oil life.
Old Jan 26, 2006 | 02:29 PM
c-5-steve's Avatar
c-5-steve
Do what the DIC says or once a year
Old Jan 26, 2006 | 02:37 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
I trust my DIC but also check the oil regularly. If the oil looks too nasty I will change it. Nothing beets checking it yourself. Also remember, unless you have a problem causing your oil to lose viscosity and you are using the full synthetic Mobil 1, that oil should last well over 5000 miles. No need to waste money on an expensive oil change if it's not necessary. I do change mine at 5000 (as recommended in the driver's manual) regardless of what the DIC says, though. Better safe than sorry.
Old Jan 26, 2006 | 03:34 PM
SLPRC5's Avatar
SLPRC5
Royal Purple 10w30 reommend changing at 12K, BUT chnage filter every 3K and top off with Royal Purple. my $.02
Old Jan 26, 2006 | 10:36 PM
MP2003Anniv50thVert's Avatar
MP2003Anniv50thVert
St. Jude Donor '06
Old Jan 27, 2006 | 08:16 AM
DeeGee's Avatar
DeeGee
I'm a DIC man
That sounded bad
Old Jan 27, 2006 | 08:33 AM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Originally Posted by DeeGee
I'm a DIC man
That sounded bad
Just follow the DIC. We have a forum member who is a retired GM (corvette) engineer that worked on the algorithms that it uses. Like the manual says, at least once per year or as the oil life monitor indicates. If you drive in dusty environments you should change it a little more frequently as it can't detect dust as well.
The manual as well as the fill cap recommend Mobil one synthetic so that's what I use.
Paul
To oil change
Old Jan 27, 2006 | 08:34 AM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
3000 mobil 1 5w30 w/ ac delco pf46
Old Jan 27, 2006 | 08:57 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
I do what the maintenance schedule recommends...
Old Jan 27, 2006 | 09:31 AM
Jim2003's Avatar
Jim2003
Roger roger
BIG 10 4
The logic programed into the computer is great!
