antenna switch
Old Jan 27, 2006 | 03:43 PM
jimmie jam's Avatar
jimmie jam
Default antenna switch
anyone have the $20+- harness that can turn power off to the antenna when playing CD? it it worth the trouble and do you truely not have to "mod" anything? thanks.
j. jam
Old Jan 27, 2006 | 05:18 PM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I did it without spending $20.00.
just go to radio shack and get spst switch ( I bought a push button switch), and some wire.
the antenna power wires run from the passenger footwell to the rear of the car, I cut the wire at the footwell and spliced my switch into it, I mounted the switch inside the center console.
one of the best $5.00 mods that I have ever done.
Old Jan 27, 2006 | 05:58 PM
mitch.smith's Avatar
mitch.smith
which wire is the power ant?
Old Jan 27, 2006 | 08:00 PM
Classic-Chevy-Guy's Avatar
Classic-Chevy-Guy
If I remember correctly, I believe it is the pink wire. I purchased my switch from Mid-America and thought that they had their instructions online.
Ran my switch from the back of the car, behind the seat, into the console.
Need a little Dremel Magic, and it fit just fine.
Old Jan 27, 2006 | 11:19 PM
TomBoy's Avatar
TomBoy
I had this done about a year ago. My husband did it for me. Bought the switch at Radio Shack. Hopefully I can link you to a couple pictures of the wiring and finished product. I use it all the time. It was allot cheaper than the kit you can buy in the cataloques.
Laurie
http://www.digitalcorvettes.com/corvette-photos/data/628/6894DSC00518.JPG[/img]]
http://www.digitalcorvettes.com/corvette-photos/data/628/6894DSC00520.JPG[/img]]
Old Jan 28, 2006 | 12:23 AM
stockC5's Avatar
stockC5
j. jam
Bought my switch at radio shack also and mounted it next to the lighter socket in the center console. Tight fit and when done correctly looks pure stock. Ran the switch leg wire under the carpet to an area below the antenna and intercepted the pink wire. I used solder on the connections with shrink tube over the splices. It's a great mod,BTW.
To antenna switch
