$3400
Old Jan 29, 2006 | 08:20 AM
Tino's Avatar
Tino
Wow $3,400 adjusted cost $0
Old Jan 29, 2006 | 08:37 AM
csexton's Avatar
csexton
Glad it turned out ok for you.
Chuck
Old Jan 29, 2006 | 08:40 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
WHOA, hold the phone.
I just had that VERY SAME problem AND had it repaired in December and my GMPP covered every penny.
GMPP Major Guard covered it all, $3114.02
**********EDIT***********
I wrote the above after reading only the first part of your post.
Then I went back and finished it..
Whew, glad it was worked out.
Now they owe you an oil change or something for almost causing you a heart attack.
Old Jan 29, 2006 | 10:09 AM
Antvette's Avatar
Antvette
Veteran: Marine Corps
Wow, I would have freaked! Good that it all worked out for you.
Old Jan 29, 2006 | 12:31 PM
silvervette02's Avatar
silvervette02
Unfortunatly I have the same problem and I need a new EBTCM as well. But I have no warranty. It actually broke when the car had a little over 35k on it but it was over the 36 month mark. I bought the car used so I didn't really have a dealer to help me out. Fread Beans is the cheapest I can find a module at $665.00. I've been driving for three months without ABS/AH/TCS and there's been a couple of times I could have used it. I can't put it off any longer but if anyone hook me up with a better price it'd really help out. I just had to buy tires too so that wasn't exactly cheap. Thanks for any help.
Old Jan 29, 2006 | 12:53 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by GeorgieMporgie
Since you just saved your self $3400, you might as well get some mods!!
Old Jan 29, 2006 | 01:10 PM
matt24's Avatar
matt24
Originally Posted by Grumpy
always get a second opinion
, glad you dodged that one but IMO GM = Morons!
Old Jan 29, 2006 | 01:30 PM
Dyno Dan's Avatar
Dyno Dan
Originally Posted by Paras
...and it turned out that one of his reps had transposed the code when he typed in the problem and that GMPP will cover the module and valve...
I understand that people make mistakes, but this is just another example of someone not doing the job they are paid to do.
If you hadn't had someone that DID care about their job and customers enough to really check it out, you would have been screwed like so many of us get because of someone not doing their job.
Sorry to be but poor customer service is just a major sore spot w/me.
Glad everything worked out for you.
Old Jan 29, 2006 | 01:36 PM
steveblonde's Avatar
steveblonde
very lucky indeed - i had a similar problem but they discovered it was just a sensor but after they put it back together and ordered a new one the problem went away
Old Jan 29, 2006 | 01:50 PM
Double Aught's Avatar
Double Aught
Way to dodge that one.
Old Jan 29, 2006 | 02:12 PM
Paras's Avatar
Paras
Originally Posted by spdislife
Good thing you didn't accept that original conclusion!
Yeah--it probably helps that my job is being a managment analyst and questioning everything... but I'll give lady luck some credit for this one...
Old Jan 29, 2006 | 02:18 PM
HummelS's Avatar
HummelS
I'm sure you'll want to take care of that service manager come next Christmas!!
Old Jan 29, 2006 | 04:06 PM
  #33
Paras's Avatar
Paras
You bet... I brought him a couple old monitors that I had in the garage and sent a little card of appreciation to let the other folks there know that he's the reason they have my business... A little care & effort, a little customer service & good will and being reasonable with your customer go a loooooooong way...
Old Jan 29, 2006 | 04:53 PM
  #34
Paras's Avatar
Paras
Hopefully someone can help you out!!!
Old Jan 29, 2006 | 05:18 PM
  #35
MY1STPEWTER's Avatar
MY1STPEWTER
Glad it worked out for you, My extended warranty will expire this April on my 01 and I hope nothing major happens. Like Grumpy said, it's always best to get an 2nd opinion.
Old Jan 29, 2006 | 05:26 PM
  #36
Johnny_B_Good's Avatar
Johnny_B_Good
St. Jude Donor '05 thru '26
The empty headed Rep who transposed the code should get his a$$ kicked BIG TIME!
Old Jan 31, 2006 | 02:47 AM
  #37
Paras's Avatar
Paras
I wonder if you can get another warranty after the extended warranty...
To $3400
Old Jan 31, 2006 | 03:16 AM
  #38
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Let us know when you get the car back that everything is fixed. I have heard of dealers changing things and charging lots of $$$ and it still had problems. Then it turned out to be nothing more then a bad grounding issue.
Clayton
Old Jan 31, 2006 | 06:16 AM
  #39
Z0SLIK's Avatar
Z0SLIK
Old Jan 31, 2006 | 06:35 AM
  #40
Glad it was just an error.
