I car that has very similar power numbers to our cars (around 350hp, 375tq) is the AMG SLK 350. Its a two door, hardtop vert... Obviously more expensive and probably slower due to weight but probably very comparable... and a beautiful car...
The SLK350 has 268 Hp, the AMG SLK55 has the Hp/Tq you mentioned above.
The SLK55 runs a 4.2 sec 0-60 & a 12.7 quarter (stock....same as a C6 MN6 coupe). The SLK is a little heavier, but has a 7 spd auto that keeps the engine in the optimal power curve so it makes up for its extra weight (due to the retractable hard top adding 200 lbs to the curb weight).
