Lowering and Alignment
Here is info from a previous thread a few months ago.
Cars response to lowering
What is happening is the roll center has been lowered so that the moment arm that goes from the roll center to the CG is longer so there is more body roll that you are trying to compensate with bigger springs. You could do what the Porsches do, i.e. compensate for incorrect geometry by having obscenely high spring rates. Some of the Porsches have 1800/2200 lb/in springs so that the geometry does not matter (watch the bouncing baby Porsche). If you do that, your shock damping has to go up as proportionally.
The only cheap thing I can think of is to put in stiffer bump rubbers on your shocks so that when you are at full bump the spring rate is higher and it limits the travel. Shock bump rubbers (actually they are urethane) are available in various stiffness. At least the tires won't hit as often.
Gary Hoffman.
...the overall diameter of the tire.
This may not help much, but a C5 with stock fender openings (regardless of tire size) needs a measurement from the spindle centerline to wheel well opening lip of at least 14" or the front roll center will be too low. By using the spindle centerline to fender lip measurement, you take the tire/wheel size out of the equation. For those with modified fender openings, you will need to come up with your own fudge factor for your fender openings.
The roll center calculator that I use is from Performance Trends, Inc. It is a slick little software package that allows you to see graphically what different ride heights, Dive and Roll do to your roll centers.
As a side note with little regard for roll centers: I usually set up the faster C5s to be between 14 1/4 to 14 1/2" up front and 14 3/4 to 15" in the rear, depending on which track we are running and which springs they are running. Go any lower and you will need shorter shocks and much stiffer springs and anti sway bars to keep things in check.
Mark "Beer" Stein
Email - Mark@motorsportimage.com
http://forums.corvetteforum.com/show...41&forum_id=23
Stock Ride heights ranges:
round to just behind the jacking puck points.
Front - Right and Left 5 3/4"
Rear - Right and Left 6"
Measured at the jacking points on the frame...
Front (Left and Right) 5 1/8"
Rear (Left and Right) 5 3/8"
HTH
C
RVETTECORVETTE OWNER SINCE 1971 AT AGE 18
Celebrating 35 years of Corvette ownership
**I'm definitely in this for the long haul!**
I drove mine for about 150 miles and the front was off a little and so was the rear.
You're not saving yourself any money by cheaping out here. $80 or so divided between longer life of 4 tires (and a touch of gas mileage) is nothing.
Both cars lowered to stock limits, both had alignment checked.
best regards -
mqqn
