Torque Converter
Old Jan 31, 2006 | 04:35 AM
freemanjc's Avatar
freemanjc
Default Torque Converter
Can anyone tell me if the Vigilante 3200 torque converter is manageable as a daily driver or should I go smaller with a comp cam custom grind (228/222 .588 .581 114.5) I would like to hear your advice on your daily driving with TC's.
R/
Julius
Old Jan 31, 2006 | 06:46 AM
Sully C5's Avatar
Sully C5
Cruise-In II Veteran
I have the Vigilante 3200, with a 3.42 rear, & a C5R-427 with a 240-244 114 XER Cam. Cars still runs well enough to be a daily driver.
Old Jan 31, 2006 | 06:57 AM
freemanjc's Avatar
freemanjc
Sully,
Do you have any problems with traction on gravel or simple driving maneuvers? How exactly does a stall converter work? Is the car not going move unless it's at 3200RPM. If so, it would be difficult with all the dead pedal space. I just need someone to explain to me how it will respond at a stop light in traffic during normal driving conditions. Your help and experience would be appreciated.
R/
Julius
Old Jan 31, 2006 | 07:06 AM
Rhode Warrior's Avatar
Rhode Warrior
No, its fine as far as traction and otherwise fine for a DD. It just puts you in a higher RPM band under acceleration. The only complaint I have is that it revs higher than stock when you are taking off, even slowly, and with my loud exhaust it is not very stealthy. Otherwise it's fine. Mine is a Fuddle Racing 3400 stall.
Old Jan 31, 2006 | 07:09 AM
Rhode Warrior
Originally Posted by freemanjc
Sully,
R/
Julius
The car will still move at low RPMs, say 1500, it just doesn't move as much as a stock TC. When you take off, I would say that it feels similar to the feeling of letting out the clutch on a manual transmission. That's the best way to describe it. If you take off a little harder, it grabs more the higher you rev. The more you press the pedal, the more it feels like you are letting the clutch out. It's a little different, but only takes about 15 minutes to get used to.
Old Jan 31, 2006 | 07:32 AM
Sully C5's Avatar
Sully C5
Here is a link for Torque Converter Info:
http://www.converter.cc/thetruth/thetruth.htm
Don't worry about driving the car. Just imagine this...I drove my wife (grandmother of 6) to Florida to pick up the Vette...~500 RWHP/RWTQ 427, high-stall converter, R Compound Race Tires...she gets behind the wheel & drove it (still does) like a champ.
With the converter, you can get great acceleration when you want it & drive conseratively if you need to.
Old Jan 31, 2006 | 07:50 AM
freemanjc's Avatar
freemanjc
Great info guys, now I understand a little bit more. One more question from this dumb sailor and I will leave it alone. If I am at a stop light or stopped anywhere, will the car idle at 3200RPM or will it idle where it is tuned too.
R/
Julius
Old Jan 31, 2006 | 07:53 AM
Rhode Warrior
R/
Julius
It will idle where you set it. One advantage to the higher stall is that you can set a higher idle, if necessary, say for a larger cam, and it wont be pulling against the brakes at a stop light.
Old Jan 31, 2006 | 07:54 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I have a Yank SS3600 and my car idles at 750rpm with a big cam. At a light, there is no creep and your car will idle normally.
Old Jan 31, 2006 | 08:51 AM
freemanjc's Avatar
freemanjc
I was looking at the fuddle racing as well. How do they stack up against Yank, and the vigilante. Their prices ARE more reasoable too. Are you satisfied with a fuddle. Where did you order your from tto?
R/
Julius
Old Jan 31, 2006 | 12:02 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
After my heads and cam install and the water settles with my wife a torq converter is next!
Old Feb 2, 2006 | 05:33 AM
freemanjc's Avatar
freemanjc
Your in the same boat I am, but I just decided to do it all at once so I wouldn't hear her fuss after the next install. I figure the best time is to do it before valentines day, her birthday, or anniverssary. I have gone tactical on her, and she never saw me coming!
Free!
To Torque Converter
