dead battery
Old Jan 31, 2006 | 08:27 PM
nephu's Avatar
nephu
Default dead battery
my vetts been in storage for the last 3 weeks due to home repaires caused by hurricane rita went to start it today guess i waited to long it was deader than the honda civic with the oversized fart can muffler that tried to race me last month.is it ok to jump start my vett or should i just buy a new battery.
Old Jan 31, 2006 | 08:29 PM
LB04CE's Avatar
LB04CE
Go get a RedTop.........
Old Jan 31, 2006 | 08:30 PM
Halfway's Avatar
Halfway
St. Jude Donor '06
get a new battery
Old Jan 31, 2006 | 08:36 PM
troy144's Avatar
troy144
Old Jan 31, 2006 | 08:53 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I'm inclined to agree - just buy a new battery. Before you do - do a search and read one of the gabillion threads that have been here about which battery to buy, do your research and then pull the trigger.
Also - while you're in the buying mode, get yourself a Battery Tender and next time hook it up if you are going to be not driving the car for an extended time. You could also simply disconnect the negative (black) lead so that the battery will not discharge.
Old Jan 31, 2006 | 09:58 PM
nephu's Avatar
nephu
yeah i thought of the negative black wire when i hear it go click click click click click
Old Jan 31, 2006 | 09:59 PM
Allzwell's Avatar
Allzwell
Cruise-In VIII Veteran
St. Jude Donor '03 thru '20
Just charge the battery and see what happens ... If you haven't killed it it will be fine.
To dead battery
