How to reprogram key fobs.
Old Feb 1, 2006 | 01:40 PM
kendo347's Avatar
kendo347
Default How to reprogram key fobs.
How do I reprogram the key fobs. I did a head/cam swap now my key fobs don't work. I am presuming this is because I disconnected my battery.
Old Feb 1, 2006 | 01:50 PM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
don't know if it works for the car battery but inside the fob it explains that when you change the fob battery you have to reprogram. should be something like stand next to the car and hold the lock and unlock buttons down together for 7 seconds...
Old Feb 1, 2006 | 01:54 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Try holding the lock and unlock buttons at the same time until the horn churps and you should be good to go.
Old Feb 1, 2006 | 02:13 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
for 5-10 seconds
Old Feb 1, 2006 | 02:38 PM
duckvett's Avatar
duckvett
2023 C7 of the Year Winner - Unmodified
2018 C6 of Year Winner
Directions for this are in your Owner's Manual under "Fob Training".
I just did this last night when I replaced batteries in both fobs, but I am going by memory and don't have the manual here to check.
Turn key to On.
Press Options until you have the blank screen.
Hold Reset until you see Fob Training (on DIC)
Press Reset again once.
You will be directed to press & hold Lock & Unlock buttons simultaneously for 15 seconds.
You will then see a message saying "Fob one trained".
Repeat for the second fob.
Check your manual to double-check this, or maybe someone can check their's and post here if this sequence is correct.
Old Feb 1, 2006 | 02:40 PM
Frozenfire's Avatar
Frozenfire
And for doing multiple fobs, follow the owners manual for the Learn Fob procedure. No matter how many times I do it, my fob often "forgets" and has to be re-sync'd. Apparently, that's common.
To How to reprogram key fobs.
