Security light came on while driving?
Old Feb 2, 2006 | 08:51 AM
Rapidity's Avatar
Rapidity
Default Security light came on while driving?
What does that mean? Driving to work normally this morning not touching a thing and all of a sudden the security light comes on and stays on. No clue why that would come on, so hopefully you guys have an idea.
When I got in the parking lot I turned it off, waited a seconds or two and restarted. All the lights went off as normal. WTH?
Old Feb 2, 2006 | 08:55 AM
jedicowboy's Avatar
jedicowboy
Use a pencil eraser from a wooden pencil and "clean" the metal contacts on your key. Hopefully the eraser will clear it up.
If that doesn't work then use a spare key and see if that causes the problem to go away before you take it to the dealership
If problem persists then you have a problem in the lock cylinder.
Old Feb 2, 2006 | 12:36 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Happen to me, I cleaned the pellet with some rubbing alcohol and it has not happened since then
Old Feb 2, 2006 | 12:48 PM
A little dirt or grime on the key or in the ignition cylinder can cause some error messages.
Old Feb 2, 2006 | 01:16 PM
Rapidity's Avatar
Rapidity
cleaned the key and everything is fine. Thanks!
Old Feb 2, 2006 | 01:57 PM
jedicowboy's Avatar
jedicowboy
Old Feb 2, 2006 | 02:26 PM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
happened on my Camaro. Unfortunately it wasn't they key, but the sensor in the ignition. Took me three days of arguing with the extended warranty company, but they finally agreed to pay for it.
Old Feb 2, 2006 | 02:38 PM
MY1STPEWTER's Avatar
MY1STPEWTER
Good info to know.
Old Feb 2, 2006 | 02:47 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Maybe it was looking into the future to warn you of a carjacking
To Security light came on while driving?
