Poor throttle response...normal?? No way
Old Feb 3, 2006 | 04:47 PM
cxs0778's Avatar
cxs0778
Default Poor throttle response...normal?? No way
I've been posting about some power loss that I've been experiencing and have been going crazy trying to pinpoint what exactly is going on. Here is what I feel now:
- The throttle response of the car has deteriorated it seems. It means that the power does come as soon as I hit the gas pedal, but a moment later, split of a second, but it gives a feeling that the car isn't as responsive anymore. And it gets a little worse as the car warms up. Someone told me its normal in vettes, is it?? It didn't seem like it before when it drove fine.
Old Feb 3, 2006 | 04:51 PM
Ttime's Avatar
Ttime
This is not normal.
How many miles does it have? A good tune might be a solution.
Good luck!
Old Feb 3, 2006 | 04:53 PM
cxs0778's Avatar
cxs0778
Its a 2001 with 36000 miles. I don't think tune-up would be required so soon and moreover, if it was the tune-up, wouldn't it be constant poor response all the time?
Old Feb 3, 2006 | 04:54 PM
cxs0778's Avatar
cxs0778
Could it be the clutch??? It did get a little soft a couple of times last week but hasn't done anything weird lately.
Old Feb 3, 2006 | 04:56 PM
JustinSwinton's Avatar
JustinSwinton
Has the throttle been checked to make sure there arent any sticky points? This happened in our old boat. Does the power come on normally when it does kick in? If not check sparkplug connections ect. It COULD be the clutch not grabbing fully for some reason...but that would be consant I would believe. I agree that a tune may be a good idea if these are ruled out, but hard to believe with only 36k miles. It is definatly not normal, as ive been in C5's that have 100k miles and the throttle was still extremely responsive!
Also, maybe post in tech section, someone there might have more knowledge! gl
-Justin
Old Feb 3, 2006 | 04:57 PM
cxs0778's Avatar
cxs0778
Oh and the weirdest thing is that it kinda started happening over a period of 1-2 days and didn't develop gradually.
Why do I my cars have problems that no ones every had...
Old Feb 3, 2006 | 04:58 PM
matt24's Avatar
matt24
Air cleaner then plug and plug wires is where i would start
Old Feb 3, 2006 | 05:01 PM
cxs0778's Avatar
cxs0778
Just replaced the air cleaner and fuel filter.
Old Feb 3, 2006 | 08:26 PM
v.vet's Z06's Avatar
v.vet's Z06
Any possibility of bad gas?
Old Feb 3, 2006 | 08:37 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
TPS sensor?
Peace
Willfulone
Old Feb 3, 2006 | 08:56 PM
currentman's Avatar
currentman
did you install a K&n By chance ?
Old Feb 3, 2006 | 09:44 PM
cxs0778's Avatar
cxs0778
No, got the stock one, they were out of K&N
And someone mentioned bad gas, I always get 93. So thats out of question.
cxs0778's Avatar
cxs0778
Originally Posted by Willfulone
TPS sensor?
Peace
Willfulone
Waiiitt...what does TPS sensor have to do with it? All my TPS sensons are bad...but aren't those just for tire pressure??
Old Feb 3, 2006 | 10:06 PM
ronnie948's Avatar
ronnie948
Cruise-In III Veteran
Default Sounds like bad gas to me too!!!
Run the tank out and go to a diffrent station. It sounds like You just got a bad tank of low octane gas. It does happen!!!!
Old Feb 3, 2006 | 10:13 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Did you make sure you connected every thing and the connections are nice and tight?
Old Feb 3, 2006 | 10:14 PM
CCA Corvette Parts
Throttle Position Sensor...not the tire pressure sensors...lol
Peace
Willfulone
Old Feb 3, 2006 | 10:17 PM
cxs0778's Avatar
cxs0778
Peace
Willfulone
lol, I was close...
well shouldn't the code show up on the DIC if this was bad?
To Poor throttle response...normal?? No way
Old Feb 3, 2006 | 10:22 PM
CCA Corvette Parts
Hard to say if it is not actually bad yet. I'm sure it would if it was fully failed...
Your on the right track...first thing I would check is the fuel filter, then the plug wires, then the plugs ( stock plugs have been known to drop a puck), then the MAF (mass air flow sensor) then the TPS, then the fuel Pump for pressure...
Good luck
Peace
Willfulone
Old Feb 4, 2006 | 08:18 PM
cxs0778's Avatar
cxs0778
Originally Posted by Don Kisamore
That A$$hole cop that gave you the ticket "prolly"sneaked in there and dicked with your PCM so that you could never speed again around the mall by your office in a 25 MPH zone that isn't marked so you can see it. LOL!
Jesus is waiting for you in the other thread...
Old Feb 4, 2006 | 08:34 PM
cxs0778's Avatar
cxs0778
Naw-he "prolly" just wants to give me a ticket!
He "prolly" wants to do more with you than just a ticket cuz you got so much love for cops and ticketing authorities
