AandAcorvette frame savers
Old Feb 4, 2006 | 09:29 AM
mperl93's Avatar
mperl93
Default AandAcorvette frame savers
I am looking for feedback on using the frame saver rocker rail kit from A and A corvette. Just wondering what you think of it. I don't have the capability to weld the frames savers to the radiator mount so I wanted to know if they work OK without doing that. Also do the jacking pucks still fit with the rocker rails?
thanks,
Mike
Old Feb 4, 2006 | 09:31 AM
DeeGee's Avatar
DeeGee
I didn't weld mine and it seems like a good fit. I've done a gentle check on the driveway with no problem.
Not tried the pucks. i'll check that out today.
Old Feb 4, 2006 | 09:35 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
no welding here..they work great
Old Feb 4, 2006 | 09:58 AM
mixermike's Avatar
mixermike
i filed the paint off the frame and one side of the wheel bracket, put a little JB WELD on then bolted them up per the instructions. hit the area with some paint the next day, everything looks good. no problems what so ever, mine are tested everytime i go out my driveway. with the rocker rails you won't need pucks, place the jack on the rocker rail.
Old Feb 4, 2006 | 10:07 AM
ROD BROWN's Avatar
ROD BROWN
Default A great addition to your car
The title says it all.I wouldn't own a Vette without them.Saved my car more than once.They are worth every penny you pay for them.
Rogue Wave's Avatar
Rogue Wave
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Weld! I didn't know people did that. Mine are bolted on and are fine.
The rocker rails install over the puck holes. I jack my car from the rocker rail in the same location as the holes.
Old Feb 4, 2006 | 10:26 AM
SnowyATX's Avatar
SnowyATX
same here......no problems
Old Feb 4, 2006 | 11:05 AM
DeeGee's Avatar
DeeGee
thanks,
Mike
The rails sit too close to the jacking points to fit the pucks. you can see from this (not very clear) picture:
Old Feb 4, 2006 | 11:25 AM
BHP's Avatar
BHP
You must be referring to the wheels not the bars. IMO, the wheels are must for any C5. No welding required.
Old Feb 4, 2006 | 11:56 AM
mneblett's Avatar
mneblett
Cruise-In VIII Veteran
Default The pucks fit ...
if you trim them back a bit:
I didn't weld my front frame savers in, either. No problems.
Old Feb 4, 2006 | 01:25 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Frame Savers won't allow you to drive over speed bumps or traverse dips at high speed, but for their intended purpose, they work great in prectecting the underside of the front facia. I had mine welded because I was concerned that a hit at just the "right" angle might cause them to rotate on axis (my name is Mr. Lucky after all ). From the posts thus far though, obviously plenty of people have had good luck just drilling and bolting.
Pucks and rocker rails are incompatible, though mneblett's idea of trimming home-made pucks is a possible solution.
Old Feb 4, 2006 | 01:39 PM
jay'szo6's Avatar
jay'szo6
I just bolted mine on.
Old Feb 4, 2006 | 02:29 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
I just bolted mine on and also have the rails and pucks will not be needed or would you be able to use them
Old Feb 4, 2006 | 02:41 PM
gknight's Avatar
gknight
Andy welded my rollers. Bolt or weld, what ever you prefer. Why not just weld, you will always need them and you can still change the wheels just as easy. My $.02
Old Feb 4, 2006 | 02:47 PM
Cscokd's Avatar
Cscokd
It would be good to weld the front frame saver wheels on....can't imagine JBWeld doing any good, but they seem to work ok without welding and I've checked them several times now. I just wish I'd put them on years ago. My C5 is lowered all the way on stock bolts, so I frequently scrape on things and the wheels are a must. As far as the rocker rails, they fit well and they were easy to put on. This is also something I should have done years ago before I ruined the bottom of my rocker panels. Now I have to get new ones with the brake ducts in them.
Old Feb 4, 2006 | 03:31 PM
jjvet's Avatar
jjvet
Bolted on wheels you should still be going slow. I figured it would be better to stress wheels than radiator supports. As for rails 2 times in 1 week.Once backing out of a drive both rear weels dropped off at same time.I heard a steel sound and it shook car no fiberglass crunch no damage As Karl would say don,t leave home without them.[ for the young ones that would be Karl Maulden on American Express I think ]sheet it,s beem so long I can,t remember. Michael Douglas was just a pup. Anyway get the combo.
To AandAcorvette frame savers
