rapid right turn signal indicator??
Old Feb 4, 2006 | 06:48 PM
lairdwd's Avatar
lairdwd
Default rapid right turn signal indicator??
I am getting a rapid right turn signal indicator. I also noticed the right front bulb is not flashing. The back bulb is fine. Am I getting the rapid inidcator because the bulb is out?
I don't want to replace the bulb unless I know for sure it's the culprit. In the past, I've associated the rapid indicator with a blown fuse, but I checked the fuses and they looked ok. Any thoughts? Thanks, Bill
Old Feb 4, 2006 | 06:53 PM
rws.1's Avatar
rws.1
Yup.... burnt out bulb
Old Feb 4, 2006 | 06:55 PM
madeouttaglass's Avatar
madeouttaglass
From: AKA Harvey Mushman-I know just enough to be dangerous "Those who sacrifice liberty for safety deserve neither"- B. Franklin
Senior Member
Cruise-In V Veteran
I hope you know someone with small hands.
Old Feb 4, 2006 | 07:16 PM
jman1's Avatar
jman1
Old Feb 4, 2006 | 07:20 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Trust me, hire the 10 yr old neighbor cause a grown up hand will never get in to change it. Good Luck!
Old Feb 4, 2006 | 07:35 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
with the others, change that bulb.
Old Feb 4, 2006 | 11:45 PM
DeeGee's Avatar
DeeGee
Turn on the headlights and back off one position to kill the lights.
Unscrew the 3 small screws on the black plastic housing around the headlight. Gently pull the housing clear. Reach down around the headlight unit and release the bulb holder. It unscrews counter clockwise but it has a plastic clip which you need to squeeze to release it. Change the bulb. Reseat the bulb holder and turn until it clicks back in place. Put the plastic housing back in place making sure to locate the small plastic tab in the bracket on the headlamp cover. Replace the 3 screws and close the lights.
10 minute job.
Old Feb 5, 2006 | 05:57 AM
doje's Avatar
doje
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
10 minute job.
That's EXACTLY what I was gonna say!
Old Feb 5, 2006 | 05:58 AM
doje's Avatar
doje
OK, maybe I was really gonna say this
Old Feb 5, 2006 | 09:15 AM
DeeGee's Avatar
DeeGee
I guess I must be really trim and slim
To rapid right turn signal indicator??
