Odd Turn Single Behavior
Old Feb 7, 2006 | 10:54 AM
Cruisin''s Avatar
Cruisin'
Default Odd Turn Single Behavior
The other day I was driving along and put my turn single to make a right turn at a red light. I was looking at my HUD and and thought "Huh, the blinking arrow is not working in the on the HUD." Then I noticed I was just being silly, because the turn single was not working at all! I tried the left side to no avail. Then I tried the Hazard blinkers and they worked! After that I tried the turn single again, and all was back to normal. I figured that it was just a aberration of some sort and didn't give it another thought.
Now I have noticed that this has happened to me once a day when I'm driving the car. Each and every time I notice the turn single not working, I shut it, hit the Hazard blinker button, shut it and then turn single works fine again for the rest of the day .
Any ideas what may be going on here? Any suggestions?
Thanks in advance for any ideas.
Old Feb 7, 2006 | 11:16 AM
ikaros74's Avatar
ikaros74
Same exact thing happened to me about a week ago...
I thought i was just loosing my mind caused by stress
The car has been raised to put some mods in since then so I haven't had a chance to see any repeat performance. I'm curious to see if other members had this issue...
Old Feb 7, 2006 | 11:40 AM
vertc51116's Avatar
vertc51116
From: Mustangs are like Tampons.. Every P*$$* has one!
never had this problem? :
Old Feb 7, 2006 | 11:46 AM
pfp972's Avatar
pfp972
Your hazard signal has to be changed as it also controls the directionals. Harzard switch is about $38 and is fairly easy to change. Only issue is the way it mounts in the dash. Try this link
http://forums.corvetteforum.com/show...6&forum_id=103
Old Feb 7, 2006 | 11:48 AM
schtick's Avatar
schtick
I had the same problem and the fix is to change your hazard light switch. I think the one I got was $25 at the dealership. Here's a link on how to change it. It's not that hard....hardest part was getting my hand in there to get the thing out.
http://forums.corvetteforum.com/show...s&forum_id=103
Scroll down the post #12. That's the way I got mine out. Haven't had a problem with it since i changed it. Good luck.
Old Feb 7, 2006 | 11:59 AM
Cruisin''s Avatar
Cruisin'
I know I could depend on you all for help ! Thanks for the info and the links.
Now I wonder if this is covered undered the GMPP ...
To Odd Turn Single Behavior
