Catback B&B Install Question
Old Feb 7, 2006 | 11:16 PM
napacruzerc5's Avatar
napacruzerc5
Default Catback B&B Install Question
Installation instructions says to "disconnect the negative battery terminal...may allow the computer to 'clear' its memory during installation".
What will this accomplish? Is it a necessary step to take?
Old Feb 7, 2006 | 11:19 PM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
Installed a few catback exhausts - never disconnected the battery. This must be a CYA thing for product liability.
Old Feb 7, 2006 | 11:25 PM
ELTGuy_C5's Avatar
ELTGuy_C5
St. Jude Donor '05
I used to write for Mitchell Repair Manuals. 99% of every repair or remove/install procedure we wrote began with the phrase "Disconnect the Battery."
In cases where the system being worked on is non electrical, it's more of a CYA and a method of ensuring the engine does not start inadvertantly.
Old Feb 8, 2006 | 12:27 AM
y2kcorvettebob's Avatar
y2kcorvettebob
Had to do that B4 working on my ex-wife.....but thats another story
Old Feb 8, 2006 | 12:53 AM
Cscokd's Avatar
Cscokd
Maybe it's a way to force the PCM to do idle re-learn or something. Can't imagine why they would say that unless it's CYA.
Old Feb 8, 2006 | 01:01 AM
army2000's Avatar
army2000
St. Jude Donor '11
Sounds like a waste of time to me. If you receive an electric shock from installing an "exhaust" at the "rear" of a car, then you got bigger problems than the battery.
To Catback B&B Install Question
