Do you know Option Codes 2K specific????
Old Feb 8, 2006 | 04:04 PM
teddyca's Avatar
teddyca
Default Do you know Option Codes 2K specific????
Now that I have found my new baby I have been checking all over the place against the VIN. Looks like she is loaded and the owner has no idea I found a few options I don't have and not sure if others cancel them out. Please help:
1SA Package Option 01- I have it what is it
AAB Memory package- What all does it remember (seat, telescoping wheel, stereo, ??? how many drivers)
F45 Varible chasis real time damping (is this the FX45 thats adjustible?)
Does this eliminate Z51 Performance handling package?
K63 LS1- Is this just the block???
Now on my list from the dealer there are a few that did not show up on the idaho corvette page and no title from the dealer. Below you will see 6 things that are not labled. I am going to search the web, but hoped for alittle insight here.
Here is what it looks like I have
OPTION CODES
AAB - MEMORY PACKAGE
AG2 - SIX-WAY POWER PASSENGER SEAT
AK5 - DRIVER & RIGHT FRONT PASSENGER AIR BAGS
AQ9 - SEAT FRT BUCKET, PASS, DRIVER
BGR
B34 - COLOR-KEYED FRONT FLOOR MATS -CARPETED
B84 - BODY SIDE MOLDINGS
CC3 - TRANSPARENT LIFT-OFF ROOF PANEL
CJ2
DL5 - ROADSIDE SERVICE INFORMATION DECAL
DL8 - HEATED REARVIEW MIRRORS
FE1 - SUSPENSION SYSTEM-SOFT RIDE
F45 - VARIBLE CHASIS REALTIME DAMPING
G90 - 3.15 GEARS
G92 - PERFORMANCE AXLE RATIO
IL3
JL4 - ACTIVE BRAKE CONTROL
JL9 - 4-WHEEL DISC ANTI-LOCK BRAKE SYSTEM
K63 LS1
MX0 - 4-SPD. AUTO. TRANS. W/OVERDRIVE
M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OD
NC1 - CALIFORNIA EMISSIONS LEV
NG1
NK4 - LEATHER WRAPPED STEERING WHEEL
N37 - TELESCOPING STEERING WHEEL
QF5 - ALUMINUM HIGH POLISH WHEELS
R9Z - CONTROL-SALES ITEM NO. 100
T82 - TWILIGHT SENTINEL HEADLAMPS
T96 - FOG LAMPS
UN0 - AM/FM STEREO W/CD PLAYER
UV6
UV7
UZ6 - HEADS UP DISPLAY
U52 - ELECTRONIC INSTRUMENTATION
VM3 - CONSUMER INFORMATION LABEL
V49 -LICENSE PLATE FRAME
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
XGG - FRONT 245*45*17
YGH - REAR 275*40*18
1SA - OPTION PACKAGE 01
19I - INT EBONY INTERIOR TRIM 193
79U - MILLINIUM YELLOW EXTERIOR
Old Feb 8, 2006 | 04:22 PM
Zilla's Avatar
Zilla
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
Where do you live Canada or US?
The reason that I ask is that the 1SA package in Canada is different that the US 1SA package. The Canadian 1SA package is the same as the US 1SC package minus the HUD.
Old Feb 8, 2006 | 04:31 PM
teddyca's Avatar
teddyca
I live in California, thats to this guy
Old Feb 8, 2006 | 05:15 PM
HummelS's Avatar
HummelS
F45 does eliminate Z51. You can improve the handling relatively inexpensively by adding Z51 sway bars.
In 2000, 1SA is just the "base" Corvette, and options were a la carte. In 2001, they started using the option "package" concept; 1SA was still base, and the 1SB and 1SC packages included other options - for instance, you had to order the high-end 1SC package to get the HUD and tilt-tele wheel.
Old Feb 8, 2006 | 07:23 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
www.corvetteactioncenter.com
To Do you know Option Codes 2K specific????
