Question for "Low Riders"
These lowered C5s look outstanding! My question is, the black plastic wind deflector thingy under the nose... Surely you guys with the lowered C5s can't go over ANY kind of a speed bump, right? If I buy a C5 (long story) I'll HAVE to lower it. But just pulling into my driveway, I think it'll scrape. (and it doesn't have a curb at the end of the driveway)
So let's hear it. Is it impossible to drive these things on public streets sitting that low??
Most important change in thinking might seem obvious, but it's one that most people do not grasp. Your C5 is NOT an SUV: stop driving it like one.
I know that sounds stupid, but you would be surprised at the sheer number of C5 owners I have observed driving their C5 like SUVs or Camrys. They just barrel along over speed humps, ramps, shopping center parking lots, transitions etc. They park nose in. They do not slow down for anything.
So, if you lower your car, learn to drive a lowered car. All transitions must be taken at a 45 degree angle and s-l-o-w-l-y, thought has to be given to potholes, manhole covers etc.
My somewhwt belaboured point is - think while driving. I have driven more than 2000 miles since I lowered it as you see in the pic - and 23,000 miles on longer bolts and no front bolt.
I have done long trips through some of the worse roads in the nation (the Cross Bronx Expressway in NY), from CT to KY, CT to Canada - all over the place.
EG
Any help would be appreciated.Thanx,
Chris
EG
, but the fact of the matter is, you can definitely be too low. (Unless it's just a show car or has air bags).
2000 miles of everywhere since the coilovers with no problems.
If you want an objective opinion - ask Connecticut or Bill Curlee or Red Vette 93. All have driven with me over all sorts of terrain.
Scraping on your frame savers is not just fine. Do you also have header savers? No offense EG, just stating my opinion.
I was driving at night this past summer on a return trip to the beach, and took the more scenic back-road route. I was in a line of cars evenly spaced moving at around forty, when BANG! I hit the lip of a resurfacing road. The road dept must have ground down the roadway in a very small section, and where it met the original road, instead of beveling the transition, they left a straight cut across the roadway perpendicular to the line of travel. Now this wouldn't have bothered a normal car since it was maybe two inches max, but with my lowered vette, it hit hard. The frame savers took some of it, but most of the impact went into the twin fans (lowered radiator). Busted my fan shroud at the lower clip (which is built into the twin fan unit). I was able to fabricate a temp fix, so we'll see how it runs this summer. Just in case, I bought a spare fan.
So, like EG says "be careful" lol, although some things sometimes can't be avoided
I got my chromed alternator and brackets on, and it turned out great. I've already got the itch for the upcoming season, and can't wait to get out there!
That's an awesome car you have there. I think you need more HP though.
! ! !I must say however, I like the EG LOW Look ! ! ! I lowered mine on the stock bolts and within 20 minutes I had it in the air replacing the rear bolts and cutting the front bushings.
But now I wish I had removed the front bolts all-together...that is a good Sunday project...
It's all relative to what you want. If you want to drive a Camry, then that all good too.
This is my 8th slammed car and 4th country and I've gotten by just fine so far in all of them.
My car:
