C5 Kill Switch
Old Feb 12, 2006 | 09:40 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by Big Red Machine
I just pull out my fuel pump fuse up under the hood, next to the battery, when I'm really concerned about the area I'm parked in. I also do this when I don't drive my car regulary so I can pump up the oil pressure before I start the car. If your'e somewhat lazy or short of time, this might not work for you.
Great idea
Old Feb 12, 2006 | 09:43 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by 502ci
An aftermarket alarm that sends you a page if your car is being tampered with, whether its a radio signal or a cell phone page. Then you can go and meet the thief in person if your close enough (this encounter will vary depending on the bad guys mood ) Although you will have to sleep with the pager for it to be effective.
I have the VIPER 5000 with inferred...let me know when someone is near it..rach in and it goes off, stand too near it i goes off ..pager alarm..works great...
Old Feb 12, 2006 | 09:54 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Originally Posted by RstyNutz
DON'T EVEN TRY IT!
Still true...the kill switch will keep someone from stealing it because they can't start it..which will get most thieves, but if someone has a roll-on it won't matter. Just like lojack, it will tell you where it is if they haven't already taken it too far and disassembled it too much.
Old Feb 14, 2006 | 01:46 AM
'04 Z06 Rocket's Avatar
'04 Z06 Rocket
I've also heard of thives who get pissed it won't start and trash the interior!
Old Feb 14, 2006 | 12:04 PM
Blown-Interceptor's Avatar
Blown-Interceptor
Originally Posted by TOOGECKO
Can you PM more details on how to do this?
Would you mind sending a PM my way with the details?
Jason
Old Feb 14, 2006 | 02:25 PM
kalister1's Avatar
kalister1
They sell battery disconnects with a small wire and fuse that keeps the memory alive while the large cable is disconnected. If someone tries to start the car the small fuse will blow.
Old Feb 14, 2006 | 03:01 PM
BAMF AE's Avatar
BAMF AE
From: The Surgeon General has warned that it's ok to smoke mustangs!
St. Jude Donor '06-'07
I've been using this successfully on my car for a couple of years now without any complaints!!! It's even reduced my insurance rates and allows me to get rest and relaxation without having to worry about my ride!
If you have any questions, please do not hesitate to advise...
Serkan
Old Feb 14, 2006 | 03:12 PM
tramminc's Avatar
tramminc
Serkan
AND I THOUGHT TAKING A GUY TO THE WOODS , TIEING HIM TO A TREE AND POURING HONEY ON HIM WAS BAD.
Old Feb 14, 2006 | 04:00 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
8 pounds of C4 wired to the door where only you can turn it on or off. They will only attempt to take your car once.
(Don't forget to tell the wife.)
Old Feb 14, 2006 | 06:11 PM
502ci's Avatar
502ci
Serkan
QUITE FUNNY! They have in Europe security systems that have an unsharpened steel blade that swings out, or an actual flame thrower below the bottom of the doors, although these are used mainly for carjackers.
Old Feb 14, 2006 | 11:33 PM
steve badalamenti's Avatar
steve badalamenti
If your car is a standard shift, you will find a HUGE plastic switch
up by the root of the clutch pedal. That is the clutch safety switch.
Cut ONE of the wires leading to it about 2 inches away from the switch.
Splice in a simple 12-volt toggle switch on a LOOOOOOOONG lead and
hide it anywhere you want.
Now, in order to start the car, you need to step on the clutch AND flip the toggle.
I've been using this setup in all my cars for years, including my C-5
