C5 Kill Switch
Old Feb 11, 2006 | 11:36 AM
2001yellow/redC5's Avatar
2001yellow/redC5
Default C5 Kill Switch
Looking for thoughts on how to / or why not to put a hidden kill switch on my C5. I was considering it as a addtional guard against theft.
Old Feb 11, 2006 | 11:50 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Just switch one of the PCM's wires. Bill Curlee knows
Old Feb 11, 2006 | 02:31 PM
2001yellow/redC5
????? Can you or someone expand on this?
Old Feb 11, 2006 | 02:43 PM
ALLEGRO's Avatar
ALLEGRO
You biggest fear is a roll-back truck. Though a "kill" switch might save you........Mid-Night Auto Delivery is your greatest nightmare.
Old Feb 11, 2006 | 03:48 PM
jrose7004's Avatar
jrose7004
If they want your car bad enough they're going to get it one way or another!
Old Feb 11, 2006 | 03:51 PM
Big Red Machine's Avatar
Big Red Machine
I just pull out my fuel pump fuse up under the hood, next to the battery, when I'm really concerned about the area I'm parked in. I also do this when I don't drive my car regulary so I can pump up the oil pressure before I start the car. If your'e somewhat lazy or short of time, this might not work for you.
Old Feb 11, 2006 | 03:56 PM
Varmit's Avatar
Varmit
St. Jude Donor '08
sawed off 12 ga works pretty good!!
Old Feb 11, 2006 | 04:42 PM
502ci's Avatar
502ci
An aftermarket alarm that sends you a page if your car is being tampered with, whether its a radio signal or a cell phone page. Then you can go and meet the thief in person if your close enough (this encounter will vary depending on the bad guys mood ) Although you will have to sleep with the pager for it to be effective.
Old Feb 11, 2006 | 06:33 PM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
Great idea.
Old Feb 11, 2006 | 06:36 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Isn't it a relay switch?
Old Feb 11, 2006 | 06:57 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Default switch
You could wire a switch to the heavy gauge yellow wire coming from your ignition. That's your starter wire. If it was me I would get an alarm that does the same thing and a little more.
Old Feb 11, 2006 | 07:05 PM
flash of red's Avatar
flash of red
If you are driving a manual tranny, you can wire in a switch to the clutch. The clutch has a switch on it that makes you push it in to crank the car.If the circuit is broken with a hidden switch the car will not crank.
Old Feb 11, 2006 | 09:31 PM
2001yellow/redC5
Thanks for the info.
Old Feb 11, 2006 | 09:53 PM
LoneStarFRC's Avatar
LoneStarFRC
That's what I did on mine. It's the easiest way to go and since there are only two wires on this switch, pick either one to splice in to. It doesn't matter. Put your extra wires in a 1/4" black wire loom and run them to wherever you want to hide your kill switch. HTH
Robert
Old Feb 12, 2006 | 11:37 AM
SEAMOORE's Avatar
SEAMOORE
Me too!!! Works great.
Old Feb 12, 2006 | 01:19 PM
flynbya2's Avatar
flynbya2
Good idea, except for the a4 guys
Old Feb 12, 2006 | 08:42 PM
TOOGECKO's Avatar
TOOGECKO
Robert
Can you PM more details on how to do this?
To C5 Kill Switch
Old Feb 12, 2006 | 08:53 PM
frodo84's Avatar
frodo84
Uneducated autodidact
Default Neutral start switch
Yeah, well...you could also wire in a switch int he neutral start circuit. Same as the clutch circuit for us...there was a thread about this somewhere last year.
Old Feb 12, 2006 | 09:08 PM
troy144's Avatar
troy144
Old Feb 12, 2006 | 09:39 PM
SLPRC5's Avatar
SLPRC5
DON'T EVEN TRY IT!
